275 60 15's in front?
I got my 1982 2wd Blazer delivered today and it has 275's on the back and 245's on the front. I was wondering if I could put the 275's on the front and how wide could I go on the back? It looks like it has still got a lot of room on both ends. It is lowered, but not real low.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 10-04-2007 at 11:25 PM. |
Hotwheels?
Im pretty sure 2/4's can take 275/60/15's no problem.
Out back a 295 fills out really well. ![]()
1978 Money Pit - CUSTOM DELUXE!!!! |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Sweet Blazer Kevin.
![]() This is mine that isn't lowered at all.... YET, but it has 275's all the way around. You shouldn't have a problem with them up front.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
1987 GMC Sierra Classic
I have 275/60 BFG's all the way around and they work great. It is better that way for tire rotation purposes.
Gary L Hilton jr |
Garage Queen Material
275/60/15's here on my 4" lowered front.
they fit good, although i did have to roll my fender lips because it was taking chucks out of the tires at first |
I'm with eric, I first have 275/60 on a 15x10 all the way around. After I did my 2.5/4 drop I had to change to a 255/60 on a 15x8 up front. It was taking chunks out of the tire anytime I hit a big bump. Stock height I was fine with them though. Hard to tell from that picture, it dosent look too low, but neither does mine. Its just the harsh bumps like going onto a bridge you have to worry about. You maybe ok with them on a 15x8 though??
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
I agree with Eric too when i first lowered my truck i had 275/60/15's and i was chopping the tire in the front with every little dip that you would hit. I now have 245/60/15's up front and 295/50/15's out back. There both the same height of tire just the back one's are lot more wider than the front's.
Sounds like yall have too backspacing on the wheels.
I have ran 275/60s for several years on my 72 and Its lowered 3/5 Never even thought about them rubbing. |
#9 | |
I didn't have them on a 72 they were installed on a 86 chevy trucl and almost everyone i know as that problem running that size of tire on the front of that year of truck. |
Yeah I gathered that Much. What im saying is the backspacing May be out too far Ive got an 85 so im familar with the wheel wells they will hold some meat.
