Old 12-03-2023, 08:07 PM   #1
pwdcougar
pwdcougar's Avatar
99 front differential in a 97
Anyone here put a 99 front differential in a 97?
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 12-05-2023, 06:39 PM   #2
b454rat
Re: 99 front differential in a 97
Why? There isn't a difference. In less your talking the NBS diff....
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 12-06-2023, 07:11 AM   #3
Should be a straight swap
Old 12-06-2023, 10:01 AM   #4
pwdcougar
pwdcougar's Avatar
The issue is that the 97 has a pigtail for the actuator and a pigtail for the 4wd engagement light. The 99 diff uses the mechanical actuator and has only one pigtail. Physically the differential bolts right up.
It took a few days of research and modifications to the wiring harness but I’ve got it sorted out.
Old 12-07-2023, 09:08 AM   #5
Is the mechanical actuator aftermarket? Glad you worked it out
Old 12-07-2023, 01:18 PM   #6
pwdcougar
pwdcougar's Avatar
The mechanical actuator was stock 99 and up for this particular front differential. Chevy got complaints about the thermal actuators slow engagement in cold weather. To upgrade to the new style there is a service bulletin and a wiring harness from GM.
Old 12-08-2023, 08:37 AM   #7
I know about the slow actuators, the reason for the aftermarket conversions. I didn't realize GM changed that in the last GMT400s. Took them long enough. Obviously only concerned with the next trucks being better in that function.
Old 12-08-2023, 07:59 PM   #8
b454rat
They had to make them quicker for the Autocrap t-cases. When in 4wd Auto, the t-case is in 2wd, but soon as it senses rear wheel spin, in engages the actuator instantly. Sorta. Best thing I did, was convert to an NP241.
