#51 |
![]() Join Date: Aug 2018
Re: wanted 8000 RPM tach Lens pic
Id be interested in one. Can you offer this in a stensil to paint it on the lens?
Carl 1971 GMC short bed, (Henry) Options I've added, tilt, ac, 8k tach, Electric speedometer conversion for LS swap, 6.0 with 823 heads and BTR stage 4 truck cam, 4L80e, posi with 3.73 rear end, Power steering and power brakes Lowered 5/7. Frame up build. |
#52 |
![]() ![]() Join Date: Jan 2005
#53 |
I'm feeling really good about how this sage green vinyl matches the original color. I made a new tach sticker out of it, along with a VACUUM sticker. This is the first time I've applied a VACUUM sticker. I had to make the letters skinnier than I had them so that they'd match the other text.
#54 |
I made some extra decals and posted them for sale.
https://67-72chevytrucks.com/vboard/...d.php?t=848683 |
#55 |
![]() Join Date: Dec 1999
Thanks for this. Looking forward to see how the 8k decal works out for my air pressure lense.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#56 |
![]() Join Date: Jun 2005
Nice job, looks factory.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#57 |
Here are a couple of KPH decals I just finished making for Canuckvetter. Let me know if anyone else us interested in one.
#58 |
Jeez.....that would be a nice addition. (The KM/H)
"If it ain't broken, fix it 'till it is!" |
#59 |
#60 |
How did I get this OLD!
![]() Join Date: Dec 2014
Those look great. Thanks again!
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Mechanical Diesel Tach, Vac, Kilometre Speedometer, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Steering Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt, Chewychevy67. |
#61 |
#62 |
I just got a message from the print shop that they are direct-printing 8k tach and vacuum text on a lens for me right now. The technician spent a bunch of time color-matching the factory text color. I'm looking forward to seeing how it turns out. Here's the proof they sent me (before color matching).
#63 |
I got the first sample lens back from the print shop. It's a lens that has cracks in it. I am impressed by the print quality. They did a nice job of color matching. One thing I wasn't expecting is that they printed a layer of white on the back of the text. I was told that this is a way to make the color not look washed out, and it helps with back-lighting. I will assemble it into a cluster later tonight so I can see how the back-lighting looks.
#64 |
The direct-printed 8k tach text lights up well.
#65 |
![]() ![]() Join Date: Jul 2003
Well done. A work of art!
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#66 |
That is sharp
#67 |
I posted a couple of the lenses I got direct-printed for sale here:
https://67-72chevytrucks.com/vboard/...61#post9264661 |
#68 |
I just finished making a custom back tin that lowered the 8k tach by about 3/16". I did this because the tach was centered in the gauge hole when viewing it straight on. You end up looking down at the gauges at an angle though, and this viewing angle caused the upper portion of the gauge to be hidden. The speedometer and fuel gauge are off-center in the downward direction for this same reason, so it makes sense to have the tach mounted the same way. Here are before and after photos.
#69 | |
| Bookmarks |
