Old 12-08-2023, 08:55 PM   #4426
pjmoreland
pjmoreland's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by Steeveedee View Post
That's very nice! My FiL put a vacuum gauge in the tach location and a tach up by the A-pillar on the dash pad. I'd rather have the tach where it belongs and the vacuum gauge in the unused hole, but there is a trans temp gauge in front of that. I'm old and don't have your energy. It'll probably be like that when my son inherits it.
...and I don't think I'll ever run that BBC over about 4500 RPM.
The addition of those gauges to your truck tells a story of what your truck has been through. I know next to nothing about the history of my truck. I wish I did!
pjmoreland is offline   Reply With Quote
Old 12-08-2023, 11:37 PM   #4427
novaX522
Originally Posted by pjmoreland View Post
Installed an 8k tach along with a modified OE lens. Designed the text based on the stock 5k tach and then had a local shop print it on there for me.
The tach looks amazing!
novaX522 is offline   Reply With Quote
Old 12-08-2023, 11:44 PM   #4428
novaX522
Had 3 friends meet me at my place after work to pick up the truck box and set it back on the frame. I got the box bolted back down. I have new 2” drop springs installed in the rear. It looks better already. Looking forward to getting the front springs done and some 31” tires on. I think the truck will look sharp.
Old 12-09-2023, 02:24 AM   #4429
Rust_never_sleeps
Rust_never_sleeps's Avatar
got my heater control back together and back in, sits a little crooked, but I'll deal with that later. Did some CAD(cardboard aided design) work on the glove box, should start bending metal tomorrow for that
Rust_never_sleeps is offline   Reply With Quote
Old 12-09-2023, 04:36 PM   #4430
Speedracer39
Speedracer39's Avatar
Installed vintage air unit under the dash and duct hoses and a few more pieces of kilmat.
Speedracer39 is offline   Reply With Quote
Old 12-10-2023, 04:50 PM   #4431
Extended Power
Extended Power's Avatar
Deleted.
"If it ain't broken, fix it 'till it is!"
Last edited by Extended Power; 12-10-2023 at 09:32 PM. Reason: Same post. Deleted.
Extended Power is offline   Reply With Quote
Old 12-10-2023, 04:53 PM   #4432
Extended Power
Applied my 0-8000 rpm stencile from PJMORELAND.
Scared I was gonna fog the lens with the spray cleaner I used, but it worked.
Thanks Patrick.
The tach went from busy and completely off, to clean and properly centered.
Old 12-10-2023, 07:29 PM   #4433
Casper42
Casper42's Avatar
Originally Posted by desert-rat View Post
Installed new cab and core support bushings. Took 4 hours. Yay me.
OH! good to know! I plan to do the same, soon. Lucky for me, I already found out my front cab bolts are not spot-welded, and there's no rusted on nut/bolts as my truck was garaged for most of it's life. My bushings aren't bad, but thought it's a good time to redo.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 12-10-2023, 07:43 PM   #4434
pjmoreland
pjmoreland's Avatar
Thanks Patrick.
Nice!!
Old 12-10-2023, 08:01 PM   #4435
SRU1436
Originally Posted by Ole Blue 71 View Post
2/4 drop complete
Which kit did you use?
SRU1436 is offline   Reply With Quote
Old 12-13-2023, 03:48 AM   #4436
Rust_never_sleeps
Played with paper dolls: First cardboard template for the glovebox interior(traced from the remains of the original) wasn't really working great for tracing out the sheet steel parts, so I started over with some skinnier stock.
Also working through a Fusion360 tutorial for bent sheetmetal parts so I'll be able to make a grown-up drawing.
Old 12-16-2023, 04:54 PM   #4437
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Got a decent clip of the new motor this morning. Finally got some dry (but cold) weather to get some more break in miles on the new combo
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 12-16-2023, 04:55 PM   #4438
CAMAROBOY68SS
Odd double post, but truck ran great. Loving the 5 speed on the highway.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 12-17-2023, 09:51 AM   #4439
Jiggers72-GMC
Jiggers72-GMC's Avatar
It sounds healthy and it looks great man, well done
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 12-18-2023, 03:59 PM   #4440
Casper42
Casper42's Avatar
Struck down, dead center, a jay-walking pedestrian in a red suit
(Holiday parade and lighting festival in the 'burbs jut outside Seattle)
Old 12-18-2023, 11:14 PM   #4441
novaX522
1968 Chevy C10 new 327 idling - YouTube
Gorgeous truck! 327 sounds great. What cam?
Old 12-18-2023, 11:26 PM   #4442
Rust_never_sleeps
Started bending metal for glovebox. I've never bent metal before and it's going about as well as I should have expected
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Old 12-18-2023, 11:35 PM   #4443
novaX522
Tore the front end apart. Rotors and calipers were new, everything else is in need of replacement. Made a list of parts to order. Cut the rivets off upper ball joints and got them out. Will need to get a tool for the lowers.
I have 1” drop springs, The original springs had 1” rubber isolators, so the front will sit 2” lower than before.
Excited to get this back together and see how it looks.
Old 12-19-2023, 12:45 AM   #4444
CAMAROBOY68SS
Just a GM L79 327/350hp cam.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 12-19-2023, 02:54 PM   #4445
Rust_never_sleeps
....and for the other end of the todo list, windshield seal leaking prodigiously :-|
Code:
            __
     ______|__]\____
Old 12-19-2023, 07:20 PM   #4446
72c20customcamper
72c20customcamper's Avatar
It may not sit a full 2 inches lower depending on how much the coil is fatigued. I put 3 inch drop springs in my 68 it went down a little over 2 1/4 inches fronts were sagging 3/4 of an inch from age
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 12-19-2023, 08:17 PM   #4447
novaX522
Nice choice. Do you have camel backs to match?
Old 12-19-2023, 08:21 PM   #4448
novaX522
Wanting to fill up the gap between tires and fender. If there is too much gap after putting 31x10.50-15s on, I’ll go with a drop spindle.
Old 12-19-2023, 09:35 PM   #4449
CAMAROBOY68SS
oh yeah. This motor came with a wicked set of 186 factory 2.02 heads. They were really ported at some point on the intakes and the exhaust ports were slightly smoothed up. Stainless valves and screw in studs. Then the intake is a 69/70 Z28 over the counter piece (only difference was a little bowtie on the rear runner behind the carb.)
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 12-19-2023, 10:41 PM   #4450
novaX522
That is great! Cool truck with an equally cool engine!
