![]() Join Date: Dec 2009
Re: Penny
The Old soup bowl lifter issue.
![]() Do you know someone close to you, That has Micrometers? Or do you have a set? You can check the crankshaft and replace the bearings With Std if they are not to bad? You are probably not going to get that lucky. ![]() You never know till you check it though. I may get Beat Up by the 2 Engine Guru's on here. ![]() That Okay Though. ![]() ![]() ![]()
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
| Bookmarks |
