![]() Join Date: Sep 2014
SB A/C Bracket Bolts
For my SB 350 V8 A/C compressor install,
I’m starting to organize and clean my A/C bracket bolts for mounting to the passenger side Rams Horn Exhaust Manifold. To verify that I have the correct hardware, can someone tell me the correct lengths of these two manifold mount bolts circled? Stock photos for reference used. Thanks
Sam 1972 C10 LWB, Hugger Orange/White 2025 GMC Sierra 1500 Elevation, Sterling Metalic |
![]() Join Date: Dec 1999
Re: SB A/C Bracket Bolts
I have this stud. GM part 3937247.
I bought it at the dealer in the late 90's. I think it's correct for the stud by #19 Overall length 3 7/8 Long end is 2 5/8 Short fully threaded is 7/8 |
2nd picture
Perfect!
I couldn’t ask for a better response. Thanks Jason
OK, thanks again to Jason for the exact bolt specs.
Now for bolt #20, is it longer because of the width of the rams horn center mounting holes. Can someone verify the length of bolt #20? The A/C components/hardware were mixed up in boxes from when I first purchased the truck years ago. Going through and verifying the seven mounting brackets and mounting hardware is a bit challenging to see if I have everything needed. Thanks again everyone.
Sam 1972 C10 LWB, Hugger Orange/White 2025 GMC Sierra 1500 Elevation, Sterling Metalic Last edited by samkost; 11-08-2023 at 01:47 PM. |
![]() ![]() Join Date: Jul 2003
3937247 is the special exhaust manifold bolt/stud on the drivers side on a 350 that the manifold tin heat stove bolts to. In addition to 1969-72 trucks, it's correct for 1976-79 Corvette.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
[quote=1970cstblazer;9257442]3937247 is the special exhaust manifold bolt/stud on the drivers side on a 350 that the manifold tin heat stove bolts to. In addition to 1969-72 trucks, it's correct for 1976-79 Corvette.[/quote
When I searched the web with this part number, several links described the Corvette application you mention. So this special headless stud bolt is wrong for the passenger side lower A/C bracket to the Rams Horn exhaust manifold or it’s dual purpose? The almost 4” inch length seems correct? After cleaning my bolts, nuts and washers, I am certainly missing this part and some mounting hardware. I called LMC to reference their diagram and they couldn’t offer any length specifications to any bolts. They also don’t offer this specific headless style stud. I am going to take some depth measurements with the brackets and the exhaust manifold to determine what length hardware is needed. I found an old forum post that said to measure and deduct 1/4 “ inch for proper fitment to the engine head. Hopefully a WTB post will help locate some hardware. Thanks for your reply 1970cstblazer
Here are some part numbers from a 1979 parts book
Much appreciated.
Very helpful info relating part numbers to their specific mounting locations Thanks again
Sam 1972 C10 LWB, Hugger Orange/White 2025 GMC Sierra 1500 Elevation, Sterling Metalic Last edited by samkost; 11-08-2023 at 03:39 PM. |
Sam did you decipher that list and figure out what the stud part number was?
PM me your address and I'll send you the stud I have. I'll probably never use it. |
I have to admit Jason I’m a little lost referencing this stud bolt.
![]() My factory assembly manual doesn’t show a specific 350 V8 diagram/picture of the lower A/C bracket to the exhaust manifold. The LMC diagram is what I have been utilizing for reference, What is confusing is that Part# 3937247 is for a Left Hand application. The bracket stud bolt is for the Right hand exhaust manifold. Not sure what I am missing but I will figure it out. ![]() I do have all 7 A/C brackets and I believe the rest of the bolt on hardware. It is just this one stud bolt that I am missing. I will PM you. Thanks a ton!
I got your PM Sam, I'm trying not to fill up my PM's...
Glad you got it, updated this thread when you figure out if it works. Might help someone in the future. |
Thanks again Jason.
Hey guys, I stumbled across this thread because I was looking for that bolt/stud as well. The bolt you listed isn't quite correct. It is 3/8 going into the head and 5/16 for the bracket. I found that classic industries sells the correct bolts as part of a set. The two pictured on the left are the ones for that compressor bracket.
#15 | |
I was just in Tucson for the Holiday visiting family. Great time and nice weather this time of the year. Saw my first Arizona desert down pour! ![]() I appreciate the above info. Need to get busy soon and get back to work on the 72. Congrats on your first post and welcome to this great forum site. Thanks again, Sam
Sam 1972 C10 LWB, Hugger Orange/White 2025 GMC Sierra 1500 Elevation, Sterling Metalic Last edited by samkost; 12-10-2023 at 11:32 AM. |
#16 |
Wow, that's amazing there is finally someone making that part. Wonder how long it has been around.
#17 | |
Funny, my past internet criteria searches came up empty and there it is from Classic Industries.
Sam 1972 C10 LWB, Hugger Orange/White 2025 GMC Sierra 1500 Elevation, Sterling Metalic Last edited by samkost; 12-10-2023 at 12:17 PM. Reason: Add |
#18 | |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced) 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold) 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced) 73 El Camino SS 454 4 speed my first big block Can you tell we are fans of longbed fleetsides & 67s Chris |
| Bookmarks |
