Old 12-21-2023, 10:59 AM   #10
Jim Boy
Re: Front coil spring question
Originally Posted by CC69Rat View Post
Ah, the infamous 'Chevy Lean'
Opinions will differ I'm sure, but after dropping as many of these trucks as I have, from 67-87. Even the S10s..
GM apparently built these trucks lower on the drivers side than on the passenger side. Was the isolator in one side, but not the other? If so, I'm betting it was in the drivers side?
If it had isolators on both sides then I'm off base.. but drivers side only imo would be a spacer to adjust the Chevy Lean.
It's hard to see on a stock height truck. But, with a big static drop you'll usually see the drivers side sits about 3/4" - 1" lower than the passenger side.
I don't know how true it is but I've read GM built the trucks this way to accommodate the difference in the crown of the road. So the trucks feel like they sit level, vs leaning toward the passenger side as you drive them.
Weird.. but I use a 3/4" Belltech spacer on the drivers side of almost every truck, S10, Blazer, etc I build. Just my .02
CC69 Rat-- I've been pulling my hair out over the slant in the truck when viewed from the rear. I have replaced almost everything front and back that could affect the tilt but to no avail. This is the first post that confirms that a tilt is there. My question is:: where did you read that GM built the trucks with this configuration built in to compensate for road crown. It's the little things that drive you nuts and makes you lose sleep. Have a good day and be good. Santa is almost packed.
Jim Boy is offline   Reply With Quote
