Old 12-21-2023, 09:36 AM   #1
paul blair
Looking for NOS ignition switch and wire connector
I have been looking for NOS ignition switch and connector, found many but none said NOS or OEM. I found plenty cheep ones probably made in china. Any one here know where to buy the best quality available? Pic of what I am working on. I wonder if this is the off idle lag that happened some times? Thanks for any information! 1970 K/10
paul blair is offline   Reply With Quote
Old 12-21-2023, 02:09 PM   #2
HO455
HO455's Avatar
Re: Looking for NOS ignition switch and wire connector
I can't remember if it was M&H or AAC wiring but, one of them sells connectors separately. I've seen both of their factory style replacement harnesses and they don't use the flexible Chinese ones.
Here is a thread I started on ignition switch failures. Currently I am of the opinion that a cleaned and inspected original or at least a replacement manufactured in the 70's is the best option. If no other option then reforming the contact shape on a new one may help curtail early failures.
I'm still using the Echlind replacement at present. But I should pull it out and do a inspection.
https://67-72chevytrucks.com/vboard/...d.php?t=818861
RIP Bob Parks.
Old 12-21-2023, 02:24 PM   #3
Rust_never_sleeps
Rust_never_sleeps's Avatar
not to derail the convo, but how does the switch cause off-idle lag?
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 12-21-2023, 02:37 PM   #4
HO455
HO455's Avatar
I'm not sure it could but I've learned over the decades that I should never state something as an absolute. Oh I just did it again.
I will say there are a lot of other causes of an off idle stumble that I would look at first before I suspected a bad ignition switch.
RIP Bob Parks.
Old 12-21-2023, 03:36 PM   #5
Rust_never_sleeps
Always true....except when it isn't ;-)
Old 12-21-2023, 05:01 PM   #6
paul blair
I was thinking loss or low voltage going to ignition circuit, but probably not. Will see if it goes away with a good switch.............
Old 12-21-2023, 05:10 PM   #7
paul blair
Engine ran fine before the switch connector burnt, just trying to find a NOS, OEM or good quality replacement......Thank You for the M+H and ACC information, I will check them out.
Old 12-22-2023, 12:04 AM   #8
1970cstblazer
1970cstblazer's Avatar
Look on EBAY for both.
Old 12-22-2023, 02:57 PM   #9
MikeB
MikeB's Avatar
I've used at least four switches that came with wiring harness kits. I don't know where they were made, but I've never had a problem with any of them. In fact, the switches in some of the American Autowire kits can handle more current than OEM, for example their 55-57 Chevy kit. Just finished up installing an AAW harness on my 69, and the included switch seemed just fine to me. Very stout feeling when switched through various positions.
Just looked for one in the AC Delco catalog, but they don't show it. Strange because that switch was probably used in most GM cars and trucks back then.
From what I see that's available, I would probably go with Standard Motor Products US84 (not the cheaper US84T).
https://www.rockauto.com/en/moreinfo...=4700&jsn=1240
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is online now   Reply With Quote
Old 12-22-2023, 03:44 PM   #10
paul blair
Thank You MikeB for this information and your experience with AAW. I will check them out. Happy Trails
Old 12-22-2023, 08:54 PM   #11
halfstep
This may be what you are looking for?
Original GM, made in USA ignition switch.
Can take another pic if necessary.
I have a few - stashed for years.
Message me if you want one.
If that's illegal, I'll have to buy in to post in for sale area.
LMK
halfstep is offline   Reply With Quote
Old 12-23-2023, 01:57 PM   #12
MikeB
MikeB's Avatar
That's pretty cool!
Mike
Old 12-23-2023, 04:13 PM   #13
paul blair
LMK
Thanks for this information, I will PM you.
Old 12-23-2023, 06:40 PM   #14
notsolo
notsolo's Avatar
And and old OEM connector probably 52 yrs old seams to be near perfect.
notsolo is offline   Reply With Quote
