Old 12-20-2023, 12:23 AM   #4451
novaX522
Re: What did you do to your truck today.The 3rd chapter
Ordered rear brake hardware kit, front brake hoses, wheel bearings, races, seals, inner & outer tie rods, sleeves, idler arm, and ball joints.
Cleaned up spindles, backing plates, rotors and calipers.
Parts should be in soon, and I can slap it back together.
novaX522 is offline   Reply With Quote
Old 12-21-2023, 08:03 PM   #4452
Extended Power
Extended Power's Avatar
After over a year of being apart for lotsa changes, I have power once again!
Everything confirmed working, except the tach. (Have not started the engine yet)
Vintage Air with DDC-4000 controller.
I made the control panel out of a block of aluminum, and installed a couple of push buttons.
The one lit up is for the electric fan over ride, working.
The other is for the electric fuel pump. (Off in the picture, but I did test it.)
Words can't explain how excited I am!
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 12-21-2023, 09:27 PM   #4453
Steeveedee
Who Changed This?
Steeveedee's Avatar
Lookin' good!
~Steven
Simi Valley, CA
Old 12-22-2023, 01:00 AM   #4454
Extended Power
Originally Posted by Steeveedee View Post
Lookin' good!
Thanks!
I should clarify...I used the stock temperature controller, and gutted it. The aluminum block/panel you see is sitting inside the stock controller, held in place by the DDC-4000 mounting brackets.
It really turned out good, I think.
The block of aluminum was like $20-$25.
No welding in patch panels, or paint matching.
Old 12-22-2023, 09:19 PM   #4455
3757chevy
3757chevy's Avatar
Very nice!
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 12-23-2023, 01:51 AM   #4456
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Went and picked up my rear brake drums from a friend who had blasted and painted them, with VHT Caliper Pain, as it drove me nuts since I installed the TT2's seeing the crusty drums through the spokes. Callipers were painted when front end was rebuilt last Winter.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-23-2023, 04:09 AM   #4457
novaX522
Working on these vehicles can be jumping down a rabbit hole. I borrowed a ball joint press and got the old joints out. That’s when I noticed some play in the A arm shafts. So I will order new upper and lower A arm shafts. Fortunately Rock Auto has a great price on them, but it all adds up.
It will be worth it when it’s done.
I was able to get all the A arms, shafts and removed out steering components. Will clean up what isn’t being replaced.
Old 12-24-2023, 04:46 PM   #4458
Extended Power
Waited for my Son to come home for Christmas, so he could be there for the first fire up of the new engine.
He took a video of it.
Exhaust just has a 45* piece on each collector to direct the exhaust away from under the truck.
https://youtube.com/watch?v=CmFBpei_...S_eN7smUFW8V8n
Last edited by Extended Power; 12-24-2023 at 04:59 PM. Reason: Video link attached.
Old 12-24-2023, 05:18 PM   #4459
'68OrangeSunshine
'68OrangeSunshine's Avatar
Nice
Old 12-24-2023, 07:19 PM   #4460
3757chevy
3757chevy's Avatar
Not today, but Friday I received a new radiator for my '35.
MIKE
Old 12-24-2023, 10:28 PM   #4461
jessemthompson
Installed courtesy lights this evening.
jessemthompson is offline   Reply With Quote
Old 12-24-2023, 11:47 PM   #4462
novaX522
Sounds and looks great! Is it for street/strip, cruiser, car shows, all of the above?
Old 12-25-2023, 12:10 PM   #4463
Chevys4life
She sounds nasty!!!!!
Chevys4life is offline   Reply With Quote
Old 12-25-2023, 12:22 PM   #4464
Extended Power
I’m trying to make it a show truck/cruiser but with this engine, there will be no long highways drives. Until I blow up the turbo 400 and replace it with a 4L75R, it will just be for intown cruises and shows.
But I have never been able to leave anything stock.
I bought the truck four years ago...it was running and so had changes done to it...but not even being able to start, and drive it for over a year, has been very hard.
I never intended for it to take that long, but it just snowballed all at once.
Sure does! The wife wanted to hear it with no exhaust, so you know...who am I to deny her? Lol
Old 12-25-2023, 02:02 PM   #4465
Already Gone
Yea, I love those under dash lights. Put them in my truck and used LED Bulbs. I put an LED bulb in the dome light as well.
Old 12-25-2023, 02:20 PM   #4466
novaX522
Where do you find those center consoles? Bench seat truck needs an arm rest. Lol
Old 12-25-2023, 02:28 PM   #4467
novaX522
Since I had the A arms off to replace the shaft, I thought I would clean them up. I wire wheeled the major crud off, glass beaded them, and painted.
Old 12-25-2023, 02:41 PM   #4468
Already Gone
Here ya go, this is where mine came from. I've changed up the interior a touch since that pic was taken. https://www.cupholdersplus.com/narro...r-console.html
Old 12-25-2023, 03:58 PM   #4469
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
that sounds pretty darn good!
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 12-28-2023, 11:21 PM   #4470
Extended Power
Got the exhaust done up to the mufflers, and called it a day.
But what's a post without pictures and video?!
3" exhaust with Flowmaster Super 44 mufflers.
Lol...gonna need a new oil pressure gauge with a higher range. The 0 to 60 psi ain't gonna cut it.
https://youtu.be/1GsllcchyT8?si=rimvyzTB5SdpH166
Old 12-29-2023, 12:09 AM   #4471
novaX522
Cleaned and painted the center link. I setup the new tie rods to match the length of the old ones. Then bolted them to center link.
Installed new ball joints and control arm shafts.
Wire wheeling front frame area to get ready to paint. I ordered new control arms u bolts from LMC, they sure take their sweet time getting my order ready before they ship it. How hard can it be to scrounge up 4 bolts and toss them in a box???
Old 12-29-2023, 12:44 AM   #4472
cab4word67
cab4word67's Avatar
I ordered a level 3 PB drop member kit
cab4word67 is offline   Reply With Quote
Old 12-31-2023, 12:11 AM   #4473
novaX522
Wire wheeled frame and inner fenders. Painted frame with rust oleum brush on satin black. Used rust oleum rubberized spray on the inner fenders.
Now that that mess is finally done, I can start re assembling the front suspension and steering.
Old 12-31-2023, 10:36 PM   #4474
novaX522
Got one side together
Old 01-01-2024, 10:40 PM   #4475
novaX522
Got both sides assembled. Installed the new shocks and upper shocks supports. Got the steering linkage installed.
Getting close now.
