Old 12-22-2023, 03:01 PM   #1
truckster
truckster's Avatar
Angry Steering Mystery - I Need Help!
I have a 1972 K/5 Blazer 4WD with factory power steering.
The front U-joints were making noise, so I decided to replace them. As long as I was going that far, I decided to replace everything under there, from the carrier bearings out. I installed new upper and lower ball joints, tie rod ends, new spindle and wheel bearings; everything replaceable. I used Spicer, Timken, and Moog parts - no cheap stuff. I also installed 3 degree caster shims between the leaf springs and the axle perch with the fat end toward the front. I set the toe-in at 3/16".
I just took it out for a drive and it's all over the road - way worse than before. Everything is tight when it's sitting, but I get up to 25 MPH and I have to make constant corrections to stay in my lane. I've thought about pulling out the caster shims, but maybe I'm missing something.
Any ideas?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 12-22-2023, 03:10 PM   #2
ZEKE68
ZEKE68's Avatar
Re: Steering Mystery - I Need Help!
Is your axle mounted below the spring or above? If it is mounted below the spring, and you put the fat end of the caster shim it the front, you removed your caster. Also have you checked the drive shaft angle?
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 12-22-2023, 03:18 PM   #3
Getter-Done
Getter-Done's Avatar
I suggest to take the shims back out.
It will not cost you any money and will Probably fix your issue.
The early bird gets the worm,
85 Chevy K-20
Old 12-22-2023, 03:23 PM   #4
truckster
truckster's Avatar
The axle is mounted below the springs. Would reversing them increase the caster, or should I just remove them altogether?
Getter-Done, I agree it's no cost and a fairly easy fix. But I'll already have it jacked up, and if I can improve the steering by increasing the caster I'd like to try that... [Edit] I'm overthinking it. I'm just going to pull them out.
Do I have the toe-in correct at 3/16"?
1995 Camaro Z/28
Old 12-22-2023, 03:32 PM   #5
Getter-Done
I looked at a few old threads and that is what other members set their toe-in at.
If removing the shims doesn't solve it I would try just a little less toe-in.
85 Chevy K-20
Old 12-22-2023, 03:45 PM   #6
truckster
truckster's Avatar
Yeah, this board is where I got the information on the shims, but they're coming out. Driving it like this is just plain scary.
1995 Camaro Z/28
Old 12-22-2023, 03:54 PM   #7
Getter-Done
I had a short-bed truck with shims that PO installed
and I had to remove them because of the wandering issue.
I don't know if that is your issue also.
That would be easy if it is.
85 Chevy K-20
Old 12-22-2023, 04:44 PM   #8
A1971Blazer
A1971Blazer's Avatar
Do you have factory front springs or lifted springs?
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 12-22-2023, 06:13 PM   #9
truckster
truckster's Avatar
It has factory springs. I removed the shims and it's better but still feels really loose. I'll get on it next week. I might try tightening the steering box, but it hasn't changed since I put it in the garage a week or so ago.
1995 Camaro Z/28
Old 12-22-2023, 06:43 PM   #10
A1971Blazer
did you check the spring eye bushings? if they’re original, it’s possible they are worn out.
maybe get another set of eyes on it while you’re turning from side to side
I just rebuilt the entire front axle and put new springs on my ‘70 Blazer and it drives better than new…obviously something isn’t quite right with yours
god luck with it, let us know when you get it figured out
1967 C10 Step side
1968 C10 Step side
Old 12-22-2023, 06:48 PM   #11
truckster
truckster's Avatar
I replaced those a couple of years ago. The strange thing is that it wasn't this loose before I replaced the ball joints and tie rod ends. Maybe I should increase the toe-in.
1995 Camaro Z/28
Old 12-22-2023, 09:12 PM   #12
cj847
cj847's Avatar
I recently had a jeep with similar issues. Here is what happened in my case.
It was "wandering" going down the street. It was ok on a smooth surface but was hard to maintain my lane when potholes were encountered. The axle was substituted in from another vehicle (ie no way to know if it was right for the leaf setup I had)
When I got the "after" alignment specs I noticed that the caster did not have a reading. The guy mentioned it is not adjustable, so he added a little toe in to help compensate for the basically zero caster.
It drove better but not great. So, I took it to the 4x4 shop and had 4 degree shims put in. It was a whole new truck after that.
In your case, it sounds like you've done a spring over and who knows what else (ie who welded the pads on the axle and are they perfect or even the same?)
If there is an old school alignment shop in your area it would be worth it to find out where you are starting from. (I know it is frustrating to pay for an alignment when the only adjustment they can make takes about 1 min).
cj847 is offline   Reply With Quote
Old 12-22-2023, 09:30 PM   #13
truckster
truckster's Avatar
The front axle and springs are bone-stock original equipment. The only thing that has changed are new ball joints and tie rod ends, and those are all Moog parts.
1995 Camaro Z/28
Old 12-22-2023, 11:23 PM   #14
Getter-Done
Is the frame cracked at the Steering box?
I always add a brace on the frame, For the steering box.
Your Frame could be flexing (More) now that everything is (Tight and Right).
85 Chevy K-20
Old 12-22-2023, 11:47 PM   #15
truckster
truckster's Avatar
It's a good idea to check that. I welded a fish plate on it a few years ago, but it's worth taking a closer look. Thanks.
1995 Camaro Z/28
Old 12-22-2023, 11:53 PM   #16
cj847
cj847's Avatar
Sorry, my mistake, I was thinking GM was spring under from the factory.
Old 12-22-2023, 11:55 PM   #17
Getter-Done
I have bought and also fabricated braces like this in the link below.
Link: https://www.offroaddesign.com/bolt-i...wd-trucks.html
These really help.
85 Chevy K-20
Old 12-23-2023, 12:53 AM   #18
truckster
truckster's Avatar
Not a bad idea. I could weld up something like that pretty easily. I do have a straight brace across the front of the frame.
1995 Camaro Z/28
Old 12-23-2023, 01:21 AM   #19
tim_mc
tim_mc's Avatar
I recently snugged up the steering play in my reman Lares steering box. Made a world of difference.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 12-23-2023, 01:55 AM   #20
Richard
If the front end is all stock, front driveline can take the extra pinion angle no problem. Use the degree shims with the fat portion to the rear of the truck. Stock caster is only around 4 degrees on these old 4x4's. Adding the 3 degree shims will get you near the alignment specs of the later 4x4 solid axle trucks.
Richard
Old 12-23-2023, 09:57 AM   #21
bowtie72
bowtie72's Avatar
Leave the shims out. If you don’t have the equipment to measure the caster and camber I wouldn’t throw parts at it expecting good results when you don’t know where it is at to start with. Check your spring bushings and the shackle hanger bushings. This is a weak spot. Replace them with poly bushings will make a big difference. Toe should 1/16-1/8” in. Anything else will eat your tires up. The rubber bushings allow a lot movement.
1968 SWB "Little White Truck"
1972 LWB LS 4l80 "Plain Jane!!"
bowtie72 is offline   Reply With Quote
Old 12-23-2023, 10:28 AM   #22
truckster
truckster's Avatar
Thanks. I have poly bushings in the springs and shackles.
1995 Camaro Z/28
Old 12-23-2023, 01:32 PM   #23
KQQL IT
At the body shop.
KQQL IT's Avatar
Any ideas?
Fat end of shim goes to the rear?
You took caster away which would make it turn like a shopping carts with a bad wheel.
KQQL IT is online now   Reply With Quote
Old 12-23-2023, 01:49 PM   #24
Sicklajoie
The Niner
Sicklajoie's Avatar
Axle above the spring - fat end on the front.
Axle below the spring - fat end to the rear.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 12-23-2023, 02:01 PM   #25
dmjlambert
dmjlambert's Avatar
Just wondering here, are 4WD susceptible to the same infamous steering center link installed backwards that 2WD C-10's get?
