72 GMC Won't start
Morning Guys I've got a 72 350 that came with my truck it's been freshind up new stock parts I've been starting it acouple time a month to keep it moving it started fine one push till today Hei distributor eldabrock carb got a hose from the fuel pump in a gas can it s getting spark and gas it turns over just a second then that's it any suggestions will be appreciated Thanks Saddletramp, Merry Christmas Guys also
![]() Join Date: Dec 2009
Re: 72 GMC Won't start
Do you see a spray of gas from the accelerator pump when you open the throttle with the breather off?
Does your HEI have 12 volts at the terminal at the distributor cap? How did you determine it is getting spark? What is the condition of the spark plugs/ Are they gas soaked?
![]() Join Date: Oct 2009
Are saying all things look correct (spark, fuel, etc) but the engine only cranks for a second or two then stops cranking completely? If that is the case I’d get a jump box or new/different batt and see if the problem persists. And Merry Christmas to you too!
