Re: Door grazing fender when opening
How's the gap at the back of the door?? If it's ok, the fender needs to go forward a bit. If the gap is wide, move the door back a bit.. All the restorers "shoot" for 3/16" gap.. All you need is about 1/8" more clearance.. The fender is bolted solidly to the cab, so cab mounts don't effect that gap..
![]() ![]() Join Date: Jul 2003
That's a fairly easy adjustment. The cowl panel will need to be loosened. Once you get the fender where you want it, then also adjust the cowl panel to share the same gap to the door as the fender.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
