Old 12-14-2023, 07:44 PM   #1
Nanook
Nanook's Avatar
Weird or what?
Just came across a 66 C10 for sale, it is a short wheel base stepside, but with an extended box. Could that be factory or dealer installed?
I never have seen one before, but I am sure some of more knowledgeable members might be able to help identify this.
It's pretty rough shape but is for sale for $2,000.
Nanook is offline   Reply With Quote
Old 12-14-2023, 07:49 PM   #2
notsolo
notsolo's Avatar
Re: Weird or what?
9ft beds came on 3/4 ton and 1 tons....thats the odd ball bed is mounted backwards
notsolo is offline   Reply With Quote
Old 12-15-2023, 02:52 PM   #3
dlbraly
dlbraly's Avatar
Re: Weird or what?
yeah, looks like the bed is from a different truck. Had to put it on backward so the axle would sort-of line up.
Who knows what else they did.
Bed, Cab, Frame
A lot of work, but that's part of the fun right?
Take Care,
Dave
dlbraly is offline   Reply With Quote
Old 12-15-2023, 11:45 PM   #4
350TacoZilla
Re: Weird or what?
If you would actually build a bed like that it would look like half the trucks running around now where the wheelwell starts right behind cab and then has ton of rear overhang. That or some of the foreign market trucks you see where they look close to the stateside ones but something is off.
350TacoZilla is offline   Reply With Quote
Old 12-16-2023, 10:39 PM   #5
cwcarpenter98
cwcarpenter98's Avatar
Re: Weird or what?
That's just a regular, 8 foot step side bed sitting backwards on the truck.
The 9 foot step sides had four stake pockets on each side and was a little longer past the rear part of the fender
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 12-17-2023, 10:15 PM   #6
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Re: Weird or what?
9 Foot bed on Wrong way When have you seen A spare tire on Right rear
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 12-17-2023, 11:19 PM   #7
cwcarpenter98
Re: Weird or what?
Here's a 9 foot bed that I pulled off a 65 c30 Coca Cola truck. Look at the two stake pockets on the step side fender. Also look at the distance between the rear of the fender and end of bed. Now compare with the backwards 8 foot bed on the truck. See how there's only one stake pocket over the fender? Also not as much distance between end of fender and rear of bed
Christian Carpenter
Old 12-25-2023, 11:48 AM   #8
factorystock
factorystock's Avatar
Re: Weird or what?
Thanks for sharing photo. The real workhorses of the era, C-30 pickups had a tuff life, low production numbers and low survival rates. I spy correct original 17" wheels, great for an authentic K 20 4x4 restoration.
factorystock is offline   Reply With Quote
Old 12-25-2023, 07:20 PM   #9
cwcarpenter98
Re: Weird or what?
I pulled the bed from that truck several years ago. Only recently learned about the somewhere rarity of those wheels surviving. I wish I would have picked them up back then! I don't know how often that yard turns over its inventory, but I'll have to figure out a time to get back there. Hopefully it's still there or at least someone else was able to save the wheels too
Christian Carpenter
