Old 11-28-2013, 08:26 PM   #26
hotrodtodd
Re: Big Block Conversion in '72 Blazer ?'s
I have installed a 454 in a 72 blazer used small block 4x4 mounts hei dist. had to gently massage firewall at distributor and lower corners of valve covers ran stock covers had to do the same on 71 swb pickup also 4x4
hotrodtodd is offline   Reply With Quote
Old 11-29-2013, 12:08 AM   #27
timski69gmc
timski69gmc's Avatar
Were both 4x's? Sounds like the 4x's have the engine set further back than the 2x's
timski69gmc is offline   Reply With Quote
Old 12-01-2013, 11:23 AM   #28
Blazer690
Blazer690's Avatar
The automatic trans mount on the frame is different. Big block only 2wd
Blazer690 is offline   Reply With Quote
Old 12-28-2023, 06:13 PM   #29
my71chev
I know this is probably a long shop. But do you happen to have any dimensions on your cuts and recessed sections on the firewall?
my71chev is offline   Reply With Quote
