Old 12-26-2023, 10:13 PM   #1
Toro
Toro's Avatar
Best seam sealer for rocker replacement?
Would anyone recommend a specific seam sealer that works well with rocker panel replacement? I was surprised how much they globbed on at the factory, it was hard to find all the spot welds.
Toro is offline   Reply With Quote
Old 12-27-2023, 02:07 PM   #2
Jason Banks
Jason Banks's Avatar
Re: Best seam sealer for rocker replacement?
I have used this - https://www.amazon.com/gp/product/B005RNFBMC
But honestly, if you check with your local paint supplier, I'm sure they could recommend something.
That's a ridiculous amount the factory used.
I was thinking, that is not a super critical joint to seal, it's mostly cosmetic. It will drain at the bottom of the rocker if water got in, but I guess it is best not to have water between the metal layers if possible.
Jason Banks is offline   Reply With Quote
Old 12-27-2023, 02:28 PM   #3
Rust_never_sleeps
Rust_never_sleeps's Avatar
I posted this already, but thought it was funny. Front cab corner stalactites
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 12-29-2023, 03:55 AM   #4
Richard
You stated best seam sealer, not least costly. I used this on my rockers and kick panel seams.
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
This was used in the drip rail https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Unfortunately, the specific 3M caulking gun is needed to dispense the product. I had access to one so it did not incur any extra cost. Both products were easy to use and worked well.
Richard
Old 12-29-2023, 08:01 AM   #5
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Best seam sealer for rocker replacement?
I used the cream colored SEM seal sealer on my Blazer.
