Old 12-29-2023, 12:11 PM   #9
binford
Re: My low(ish) budget OEM build
Looks good
Question, why not use the stock transmission crossmember?
I suspect you needed it to be lower for clearance?
If trans is 7⁰ down the axle pinion should be 7⁰ up. The engine/trans doesn't know that it's tilted except for the fluids.
Since the engine/trans is an oil pressure system you should be fine.
binford is offline   Reply With Quote
