Old 08-19-2004, 01:30 AM   #1
jlmtrout
wiper w/washer nozzles in blade
Does anybody remember what cars came with the washer nozzles in the wiper arm? It seems like some trucks had 'em also if I remember correctly. I can't seem to get my stock nozzles aimed and tightened down properly, I either shoot washer fluid over the top of the cab or directly into the wiper blade. I know some foreign cars have the nozzles in the hood, but this isn't a foreign car and I don't want to start drilling holes in an otherwise perfect hood. Thanks to all who have a better memory than mine. Good luck and keep on truckin'.................Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
Old 08-19-2004, 01:34 AM   #2
Russell
Professional Grade
Russell's Avatar
My buddy's 91 burb has em, they are reallly cool, and if he gets rid of the truck, I plan to get them from him first :P
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-19-2004, 01:43 AM   #3
1969 GMC
1969 GMC's Avatar
That sure would be nice...mine didn't work when I bought my GMC (SURPRISE!!!!1) but when I hooked up my CarQuest pump, the spray hit the wiper blades. Wtf? So I tried to adjust it, but they shot over the cab, like you said. I finally got it to spray right over top of the wipers at rest, which happens to be way high on the w/s, and partially above it. No thanks!
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-19-2004, 01:53 AM   #4
jlmtrout
Thumbs up
Thanks Russell, I'll start looking for a 'Burb to use as a donor.
Old 08-19-2004, 08:10 AM   #5
Huck
Huck's Avatar
Before you spend the money, check on the length of the arms as most newer vehicles have much bigger windshields and much longer arms, something that is not easy to shorten.
Huck is offline   Reply With Quote
Old 08-19-2004, 08:13 AM   #6
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
I had an 86 C10 pickup and an 86 Suburban and they were both on the wiper blade. I think they were 16". Hope this helps.
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt."
Ben Franklin
1970 Chevy shortbed
2002 Harley Custom Chopper (Long sucker)
1998 K2500 5.7L 5-speed Longbed
1st two are My son's toys...they just live in my garage!
1997 GMC K1500 Suburban
1993 S-10 Blazer 4D (youngest son's daily driver)
2000 Dodge Ram 4WD Ext. Cab (5.9L)
Wife is a late year 1951
Old Dave is offline   Reply With Quote
Old 08-19-2004, 09:11 AM   #7
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
The 70's/80's Dodge vans had that too.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-19-2004, 09:49 AM   #8
Dean
Dean's Avatar
My 85 C20 has that.
Dean is offline   Reply With Quote
Old 08-19-2004, 10:03 AM   #9
dallas71
dallas71's Avatar
The Corsica had them also and i believe that they were
clip-on type of fitting......
dallas71 is offline   Reply With Quote
Old 08-19-2004, 08:05 PM   #10
skid
My 74 Vette has them as well. Also the Chev 1 tons up to 92 had them (from around '85), before the body style change.
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 08-20-2004, 02:16 AM   #11
jlmtrout
Thanks guys, at least now I have some idea of what/where to look for. I knew you guys would come through for me. Thanks again to all who contributed. Good luck and keep on turckin'.....Jerry
Old 08-20-2004, 07:12 AM   #12
1972C10
1972C10's Avatar
My 85 C20 Scottsdale Has Them.
1972C10 is offline   Reply With Quote
Old 08-20-2004, 08:03 AM   #13
68C15
blood type; Retumbo
68C15's Avatar
check with NAPA for a "wet arm conversion" we use them on med. duty trucks.
Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
