Old 12-31-2023, 11:06 PM   #1
44SAA
Intake Manifold Oil Leak
I have oil pooling on both sides of my manifold between the carb and valve covers. The oil is not escaping from the top of the valve covers. Is it possible this oil is escaping from the 2 manifold bolts? I tried to snug the bolts with a wrench but the carb makes wrench access a challenge. Thank you
44SAA is offline   Reply With Quote
Old 12-31-2023, 11:42 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Intake Manifold Oil Leak
The threads on those bolts are Thru holes.
You can try put the silicone in the link below,
on the threads of the 4 bolts.
Pull them out one at a time and clean and coat them with silicone.
If that don't work then it's intake gasket time.
Link: https://www.amazon.com/Permatex-8187...0002UEOPA?th=1
The early bird gets the worm,
84 Chevy K-20
Old 01-01-2024, 02:14 AM   #3
Dead Parrot
Also make sure your PCV valve and air filter are working. A malfunctioning PCV system can cause pressure buildup in the crankcase and might lead to oil coming out where it normally won't.
Sometimes those bolts can be tightened with thin wall sockets and a u-joint. But 2nd the idea of some kind of sealant first.
Dead Parrot is offline   Reply With Quote
Old 01-01-2024, 02:49 PM   #4
44SAA
Removed manifold bolts, cleaned and applied copper Permatex. FYI- challenging to do this with carb in the way, much less torque them to spec…..
Question- I just removed the AC bracket that comes off the manifold. Couldn’t help but notice both bolts were dripping w oil. Dipped a q-tip in the bolt holes and there was lots of oil in them.
1) are these AC mounting bracket holes going all the way into the manifold?
2) assuming I’m safe applying permatex to these bolts as well?
Thank you
Old 01-01-2024, 02:50 PM   #5
cadillac_al
Yes, those bolts are supposed to be sealed. I think Permatex #2 works much better than silicone in this application.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 01-01-2024, 03:14 PM   #6
Getter-Done
Bolts like the ones in the links will give you better access and you can tighten those easier.
These are just for Example.
Most of these are short and are only used without brackets.
Just make sure you order some that with be long enough for your Brackets
Link: https://www.ebay.com/itm/36333811508...2057b23e693429
Link: https://www.ebay.com/itm/11598377356...f8bf59c61bd5fe
84 Chevy K-20
