#276 |
Re: 1958 Apache Big Window Loooooong Bed "Lucky"
Since FlatOut is in SoCal, and I'm just 6 hours north, I got my part super fast and tossed it in yesterday.. HUGE difference in space, and whaddya know, the rear suspension actually has travel now!! I used to think my spring rate was way too high...
![]() ![]() Waaay more room with this setup, not to mention the ease of adjustability(which wasn't needed but was appreciated!)
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
#277 |
More photos where you can see how lowering the center point and mounting below instead of above the link attachment point really added a good amount of clearance.
Clearly, Don has seen this issue numerous times over the years! The kit also keeps a nice geometry that allows these rods to stay roughly parallel with half shafts, which I understand to be necessary for this suspension to function well. I think I could still find a DIY solution, but it wouldn't look this sexy. Also check out how perfect the Mustang tank is for providing access to the centerpoint! It looks like I planned it that way all along.
#278 |
that looks good. prolly less tire wear now too as they would likley toe in and out, with the old set up, as your suspension moved. well, maybe not if it couldn't move, lol.
#279 | |
Next up for the rear is seeing if I need to roll/trim the fender lip to clear these 225 BFG's....right now there is enough camber on each wheel to prevent rubbing, but if I correct that, I miiiiiight be in trouble!
#280 |
Personally I like a finger space between but that's just me. You could space the fender away from the box if need be.
#281 | |
I do as well, but not enough to buy new tires or make custom fender extensions ![]() ![]()
#282 |
Drivers side door is looking pretty complete!
This looks like just a regular old boring door... but I have spent HOURS to get to this point.
#283 |
looking good. I had considered buying that flip kit back when I bought my flat out kit. I think the price has gone up $100 since. Guess I shouldn't have waited
I just installed some repo exterior door handles and arm rest. I was surprised that the aftermarket interior trim panel did not come with the holes for the arm rest drilled.
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90 http://67-72chevytrucks.com/vboard/s...d.php?t=746958 |
#284 | |
I drilled new holes and raised the brackets on the rear kit, and I'm also at the very bottom of these coilovers, so you might not need it. The FlatOut kits sit too high in the rear for my tastes, which is why I adjusted the brackets and narrowed the frame channel. I know you are hoping for yours to come down with some bed wood, but just have someone stand in it and see if you like the height...better to address it now!
#285 |
The last bit of regular progress has been fueled by one mission: Go on a lil cruise with my Grandpa while he's still around (which isn't much longer).
Grandpa got me started tinkering on things when I was little, so it's only fitting. Mission Accomplished.
#286 |
![]() ![]() Join Date: Oct 2014
Very nice!!!
#287 |
Thats awsome!
#288 |
![]() Join Date: Aug 2010
Happy New Year and congrats on mission accomplished !
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
#289 |
Awesome!!!
#290 |
Well done, That is great.
congratulations
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
#291 |
Thanks, yall. I'm glad I got to have this moment with him.
I'll probably start tinkering on it again soon enough, it still needs plenty of work... a whole interior, a flip up bed, some wiring clean up, and who knows what else, but that stuff alone will keep me pretty busy
#292 |
Time for an update ?
#293 |
It SHOULD be, but I haven't touched the truck in a lil bit.
If I do any tinkering right now, its going to be on your 56 big block!
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo Last edited by daveshilling; 03-03-2024 at 03:29 PM. |
#294 |
Don't know if you're still looking, but these are still available and the price is dropping and open to offers.
https://www.jalopyjournal.com/forum/...uards.1303192/ |
