Old 01-01-2024, 10:56 PM   #1
novaX522
Control arm shaft torque?
I installed new upper and lower control arm shafts. I just snugged up the end nuts for now. What is the torque for the end nuts?
novaX522 is offline   Reply With Quote
Old 01-01-2024, 10:58 PM   #2
pappy 2
Re: Control arm shaft torque?
until they stop turning?????
pappy 2 is offline   Reply With Quote
Old 01-01-2024, 11:20 PM   #3
novaX522
I’m pretty close to that now, just wondering if there was a specific torque for them.
Old 01-02-2024, 12:04 AM   #4
Rust_never_sleeps
Rust_never_sleeps's Avatar
I have this from the '70 manual, not sure what year you're working on:
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 01-02-2024, 12:06 AM   #5
dmjlambert
dmjlambert's Avatar
The torque specs are in the service manual. If you don't have a printed copy, there are PDF copies of the various year service manuals here on the forum. https://67-72chevytrucks.com/vboard/....php?p=5781194
Old 01-02-2024, 10:41 AM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
A lot!
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 01-02-2024, 11:57 AM   #7
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
All the impact wrenches at the assembly plant were set for the proper torque to save fastener installation time, at least in '70. I wonder if there was a wrench that went to 280 Ft-Lbs in those days? If a person had to do it, that's one big gorilla! When I rebuilt the front suspension on my truck, my 300 pound son stood on the lower a-arm while I used a 3 foot cheater bar.
~Steven
Simi Valley, CA
Old 01-02-2024, 01:46 PM   #8
novaX522
Thanks! Working on a 72
Old 01-02-2024, 01:48 PM   #9
novaX522
Thanks! I’m on my cell now, will see if I can download it on laptop
Old 01-02-2024, 01:51 PM   #10
novaX522
Originally Posted by GASoline71 View Post
A lot!
Gary
Agreed. Cause that’s exactly how much it took to un torque them. ALOT. 😂
Old 01-02-2024, 01:55 PM   #11
novaX522
The guy that torqued that daily, you call sir. lol, or whatever he wants to be called.
I have a 3/4 drive torque wrench I bought when I had a motor home. I don’t need it very often, this sounds like one of those times.
Old 01-02-2024, 03:25 PM   #12
Rust_never_sleeps
I believe the equivalent is one metric sh!+ Ton
...or...Tonne, I suppose....
Old 01-02-2024, 05:10 PM   #13
68Gold/white
THat's crazy...I'm rebuilding the front end of a friends 1971 C-10, today it will ALL be done!!!
I've worked on this stuff before....but mostly on 73-up stuff...I've taken some 72 and earlier stuff apart, for the parts, but never properly re-built any...
I'mm amazed that upper and lower control arms on 63-72 do NOT ride on ANY rubber bushing like 73 and up do??? THe rubber bushings only seem to be a well to keep the grease close to the pivot points, on the upper and lower control arms???
One U-tube video I watched, a couple of days ago, the installer said the lower arm shaft nuts were tightened to 100 ft/lbs...??? You should NOT tighten them untill the lower arms are attached to the frame. Getting the peg aligned with the hole in the lower shaft can be a doozy. ALSO, I would NOT tighten the lower shaft end nuts until you grease them.
I've worked on a lot of stuff. I'm still not sure of the theory of the upper and lower control arms actually was made to work???
One of the lower control arm end nuts was broken (crushed?) on the pickup I'm working one. I know that all the end nuts need to be tight, but the specs sound a little high?
I will try to make another post with pictures, here soon, I gota get this thing done, NOW!!!
68Gold/white is offline   Reply With Quote
Old 01-02-2024, 11:17 PM   #14
Steeveedee
Steeveedee's Avatar
Torque spec for replacement lower control arm shaft nuts is 135 Ft-Lb, not 100. Uppers are 115.
~Steven
Simi Valley, CA
Old 01-02-2024, 11:50 PM   #15
novaX522
So I got new shaft and nuts (doesn’t sound right saying that) and reusing the original A arms. What is the torque in that scenario?
Old 01-03-2024, 10:31 AM   #16
Steeveedee
Steeveedee's Avatar
According to the specs, lowers are 280, uppers are 190. But you are using replacement parts, even if they are new.
~Steven
Simi Valley, CA
Old 01-03-2024, 10:50 AM   #17
jumpsoffrock
Do you understand why the torque is different between "new" and "replacement"?
Aren't you replacing things with "new" parts?
I am confused as to why it is worded like that.
jumpsoffrock is offline   Reply With Quote
Old 01-03-2024, 01:56 PM   #18
Steeveedee
Steeveedee's Avatar
Nope. I don't get it, either. But I'm sure that the replacement parts are going to be new. HTH
~Steven
Simi Valley, CA
Old 01-03-2024, 02:33 PM   #19
novaX522
The wording is confusing. Does GM mean if you’re adding replacement nuts to an old shaft? I could see that.
I guess I’ll torque them to the replacement value and check them again after some driving.
Old 01-03-2024, 03:58 PM   #20
Steeveedee
Steeveedee's Avatar
I torqued mine to the replacement value but have never checked them in the intervening years. Of course, the truck has been driven maybe 8k miles since. When it gets to 20k miles and is due for front wheel bearing service, I'll check the torque. The rate I'm going, that'll be when I'm 80+.
~Steven
Simi Valley, CA
Old 01-03-2024, 06:02 PM   #21
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I don't have a torque tool for those big nuts. I greased the threads and took a BA crescent wrench to stop, followed by a grunt.
Nice undercarriage, BTW.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-06-2024, 12:17 AM   #22
novaX522
I picked up a set of sockets from harbor freight that had both 1 3/8” and 1 5/8” sockets. I backed the nuts off and pumped grease in and wiped some on the threads. Then torqued the uppers to 115 and lowers to 135.
Glad to have that done.
Old 01-06-2024, 10:39 AM   #23
jumpsoffrock
Thank you for including the socket size, now I know what to look for. What size truck do you run? I wonder if they are the same size for a 1-ton.
Old 01-06-2024, 04:23 PM   #24
MikeB
MikeB's Avatar
I forget which manual I used for specs when I did mine years ago, but no way were they the "new" numbers in the chart above. That chart is a bit strange showing the torque for "bushings" when there are no bushings.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-07-2024, 12:10 AM   #25
novaX522
This is a c10.
