Old 12-31-2023, 05:54 PM   #176
CurtaChevy
Re: turbo task force
Any updates? Really keen to see how you got on with your new intercooler set up.
Thanks,
Joe
CurtaChevy is offline   Reply With Quote
Old 01-03-2024, 02:56 PM   #177
akdg87
akdg87's Avatar
Thanks,
Joe
i will get some pics of it but it seems to be working fine, i did swap to a S491 turbo from work turbochargers. I dynoed again and it did 840 on 15 psi. (pump gas). Looking at the data log its flowing just fine up to around 16 PSI (1:1) then it starts need a bit more pressure on top of the wastegates to make any more boost.
Right now I'm swapping in a "turbo" cam and the BTR shaft rocker setup. Still had pretty dismal results at the track which i believe is how tight my converter is. I cant build much more than 1-2 psi on the footbrake and its 60' is in the high 1.7's.
This trans has not skipped a beat since 2017 but I'm going to swap to a different converter (higher stall) and throw some nice billet parts in the trans while its out getting refreshed.
1320 video came up for our cash days event and there's a couple clips of the truck in there. Wide variety of cars on a poor traction surface.
https://www.youtube.com/watch?v=CwvB2OZkPLU
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
