Old 01-01-2024, 10:48 PM   #4476
3757chevy
3757chevy's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by novaX522 View Post
Got both sides assembled. Installed the new shocks and upper shocks supports. Got the steering linkage installed.
Getting close now.
You are replacing those brake hoses I hope.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 01-01-2024, 11:16 PM   #4477
novaX522
Yah, I have new hoses. Just waiting til I get the brakes on before I replace them. I got the driver side line to break free from brake hose. The passenger side would not break free. I had to cut the brake line, install a new fitting, and double flare the brake line.
novaX522 is offline   Reply With Quote
Old 01-02-2024, 03:28 PM   #4478
Rust_never_sleeps
Rust_never_sleeps's Avatar
I had not anticipated just how badly I su<k at fabrication, still working on the glovebox :eyeroll:
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 01-02-2024, 10:52 PM   #4479
3757chevy
3757chevy's Avatar
MIKE
Old 01-02-2024, 11:23 PM   #4480
Extended Power
Extended Power's Avatar
Almost done the exhaust...need another support hanger on each side.
But I couldn’t wait to hear it with the 4” side pipes.
https://youtu.be/vtFRFWl6ngs?si=RvuSBsvg6Q9I7DJR
I also installed the pressure sender for the new oil pressure gauge, as the stock one still reads about 40psi when the truck wasn’t running. Need to pull the cluster out, and work on that, but I gotta clean up the shop first...metal work is so messy.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 01-02-2024, 11:57 PM   #4481
dmack91
dmack91's Avatar
Trying to free up space in my shop so I can move the truck in. So I painted a set of ralleys and mounted some used TA radials to make it a roller. Then adapted a squarebody seat into it. Baby steps.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 01-03-2024, 09:40 AM   #4482
TheRealJimmy
installed a 1 1/2" shorter steering column and lowered the seat 2" with aftermarket brackets. Much more comfortable to me.
TheRealJimmy is offline   Reply With Quote
Old 01-04-2024, 12:17 AM   #4483
novaX522
Tonight I replaced the bearings and races. Got the bearings packed and the brake rotors installed. Installed the calipers and pads and new brake hoses.
I still need to bleed the brakes, grease ball joints and tie rods and install cotter pins. But I had to put the tires on and see if it sat different with new springs. I put 1” lower springs and removed a 1” spring spacer up front. There was 8” between tire and fender and now there is 6”, math never fails. Lol. I plan to replace the 27” tires with 31” tires, so that will get it down to a 4” gap.
Old 01-04-2024, 12:51 AM   #4484
Extended Power
Finished the exhaust on the truck.
I'm not a welder, but it shouldn't fall off anyways...
Old 01-04-2024, 12:55 AM   #4485
raggedjim
raggedjim's Avatar
novax522, nice work, but your upper a-arms are on the wrong sides. It's a common mistake.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 01-04-2024, 11:11 AM   #4486
novaX522
Good luck, Rg
Wow, you are right! Glad you pointed that out before I tried to drive it. I’ll add that to the list of things to do. 2 steps forward and 1 step back. 😂
Old 01-04-2024, 11:48 AM   #4487
raggedjim
raggedjim's Avatar
Been there and sometimes still do it! Good luck, Rg
Old 01-04-2024, 11:40 PM   #4488
novaX522
Good luck, Rg
I got the upper A arms on the correct sides tonight. Thanks again RG! Glad you caught that. I’m going to try to use this as a good excuse to buy another c10. That way if I have one tore apart, I can use the other one as a reference. Lol. Probably won’t work, but worth a try.
Old 01-05-2024, 12:04 AM   #4489
raggedjim
raggedjim's Avatar
Great job, that looks much better. The alignment shop would have found it, but it would have cost you!
Old 01-05-2024, 10:53 AM   #4490
LUCKTRUCK
LUCKTRUCK's Avatar
"what did you do?.... sadly, nothing on the trucks in quite some time. Maybe once all of this certainteed siding and Rockwool insulation is installed on the house, then it will be back to trucks.
How many do you spot?
LUCKTRUCK
LUCKTRUCK is offline   Reply With Quote
Old 01-05-2024, 12:57 PM   #4491
Chevys4life
Possibly 3 maybe?
Chevys4life is offline   Reply With Quote
Old 01-05-2024, 05:29 PM   #4492
'68OrangeSunshine
'68OrangeSunshine's Avatar
Is that a reddish Stepside buried forward of the 2-tone Orange/White cab on the left?
Old 01-06-2024, 12:08 AM   #4493
novaX522
Got all the tie rods, ball joints, idler, and pitman nuts snugged and cotter pins installed. Got everything greased. It doesn’t sound like a lot, but it took a while.
Old 01-06-2024, 01:52 PM   #4494
Casper42
Casper42's Avatar
finally found a great 1157 LED bulb that is bright, fits and performs...and reasonably inexpensive. Amazon has them in stock at their fulfillment centers so shipping is fast.
My comparison pic doesn't represent the performance perfectly, as photographing a bright light source is very challenging and it blows out the image.
Backstory: I didn't want to swap out the OE lens with one of those printed circuit board type lenses to get some brightness to the back. So over the past year, I have gone thru and tested numerous 1157 LEDs with little success. Many bulbs will not even mount in the socket as they bottom out before you can twist it to get it secured. Others were nearly hyperbright and had not brightness differentiation when you hit the brake pedal. The last ones I had, where the Sylvania 1157s that anyone can purcahse at any autopart store. These worked, but were dim in the standard "on" position, in fact dimmer than incandescent.
In short, if you want to be seen from behind when you hit that brake pedal, and still have better than OEM brightness when just cruising, these are the ones! We'll see how long they last!
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 01-06-2024, 06:44 PM   #4495
Sicklajoie
The Niner
Sicklajoie's Avatar
Took the Bomber for one last spin today before the snow hits and the salt gets laid down.
It's almost unheard of in Connecticut for it to be this late in the season with no snow yet, so luckily I was able to enjoy driving it for this long till spring.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 01-06-2024, 09:38 PM   #4496
68bowtie
68bowtie's Avatar
Great looking pickup
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
68bowtie is online now   Reply With Quote
Old 01-07-2024, 12:04 AM   #4497
novaX522
Started on the rear brakes today. Got one side done, also need to make new rear brake lines.
Old 01-07-2024, 07:17 PM   #4498
novaX522
Got the driver side brakes done and both sides adjusted. Took before and after pictures.
Old 01-07-2024, 07:40 PM   #4499
novaX522
Started on the rear brake line. There was nothing wrong with the existing brake line, other than it looked like crap. I had some leftover brake line material from when I redid the brakes on my elCamino. It is a copper/tin alloy. No rusting and super easy to bend. Got one side done tonight.
Old 01-07-2024, 10:22 PM   #4500
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ I like that NiCopp line. I'm considering replacing the 54 year old line on my truck with it, just for general principles.
~Steven
Simi Valley, CA
