Old 01-08-2024, 01:42 PM   #1
Restrorob
The One And Only !!!
Restrorob's Avatar
AC Issue
Hey guys, I'm having a issue with the AC in my 97 GMC.
When I bought it some 9 yrs. ago the AC didn't work due to no refrigerant in the system, I pulled it down and charged it to leak test the system and everything worked fine and it blew cold. I found the evaporator was leaking, I never replaced it because I only drive it to car shows in the area.
Fast forward to now, I'm ready to rip the whole dash apart for the evaporator replacement. I jumped the high and low pressure switches to make sure everything was still working okey, I found the compressor clutch kicks in when I push the AC switch on the dash but then it kicks back off when I turn the blower switch on, as long as the blower switch is off the clutch stays engaged.
In all my years as a auto tech. I've never ran across something like this, any ideas where to start diagnosing ?
Thanks !
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-08-2024, 04:00 PM   #2
sntrym95
sntrym95's Avatar
Re: AC Issue
Sounds like the control panel to me. That's where I would start.
Mike
sntrym95 is offline   Reply With Quote
Old 01-08-2024, 07:51 PM   #3
Restrorob
Restrorob's Avatar
Re: AC Issue
Thanks Mike, I'll take a look there.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
