Old 01-08-2024, 07:13 PM   #1
murguia
Carb choke thermostat help
Looking to learn.
Been going nuts hearing a knocking type noise when I am driving 0-30mph. Thought it was lifters, exhaust… but changed all of those and they were good.
Today we looked at the choke thermostat and the coil/spring was broken, so it hasn’t been working. There’s a pinhole directly under that area and sure thing, when we plugged that hole the noise went away.
How does this choke thermostats work and is that hole suppose to be there?
Should I just plug it if my truck has been running well with the thermostat broken and not working?
Thank you
murguia is offline   Reply With Quote
Old 01-08-2024, 08:17 PM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: Carb choke thermostat help
I've never seen that. I'd plug it myself, but maybe more eyes on and reasons will change my opinion.
~Steven
Simi Valley, CA
Old 01-08-2024, 08:40 PM   #3
RustyPile
RustyPile's Avatar
That hole isn't supposed to be there.. The noise you hear is exhaust gasses passing through the hole.
On the bottom of the manifold is a passage that connects the exhaust ports in each head.. Its purpose it to heat the carburetor to aid in cold weather operation.. It gets extremely hot and provides a perfect place to mount the choke thermostat..
You might meet with some success plugging it, but your best approach is to replace the manifold.
RustyPile is online now   Reply With Quote
Old 01-08-2024, 08:58 PM   #4
dmjlambert
dmjlambert's Avatar
It looks interesting, it's a nice round hole. I wonder if it's rusted through and the metal is really thin there.
Old 01-08-2024, 09:25 PM   #5
murguia
I plugged it and the noise it gone and it’s running great. I plan to leave it like that and not reinstall the choke thermostat, unless someone convinces me otherwise.
Old 01-08-2024, 09:50 PM   #6
murguia
I was wondering the same thing. Thing for sure and perfectly round.
Old 01-08-2024, 09:57 PM   #7
geezer#99
geezer#99's Avatar
If you indeed changed all the lifters I hope you don’t get unlucky and get rewarded with a flat cam.
geezer#99 is online now   Reply With Quote
Old 01-08-2024, 10:08 PM   #8
murguia
Can you educate me? one person told me it was a lifter on the passenger side that needed to be adjusted. So I warmed the truck up and loosened the bolts one by one until I hear clattering. Then I tightened until it was gone, then 1/4 then more. Did this on just the passenger side. All were throwing out oil well. Did I do something potentially harmful to the engine?
Old 01-08-2024, 10:19 PM   #9
geezer#99
geezer#99's Avatar
You’re good.
You wrote you’d changed lifters. I thought by that you’d replaced them all with new lifters. But you had just adjusted them.
The lifters mate for life with the cam.
You adjusted them correctly.
Old 01-08-2024, 10:28 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Sounds like you just adjusted lifters and did not actually replace them. So you're good. Problem would be if you installed new lifters and kept the old cam.
Well, Geezer beat me to it by several minutes. I know I type slowly, but geeeezz!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 01-08-2024, 10:28 PM   #11
dmjlambert
dmjlambert's Avatar
So, how do you plug a hole like that?
Old 01-08-2024, 10:55 PM   #12
geezer#99
geezer#99's Avatar
Self tapping screw would work.
Old 01-08-2024, 11:02 PM   #13
murguia
Really appreciate all the quick responses and help, as usual. Love this forum.
To plug I used a self tapping screw with a little copper heat tolerant sealant around the threads.
Old 01-08-2024, 11:12 PM   #14
Steeveedee
Steeveedee's Avatar
If you are in LA as in Los Angeles as opposed to LA as in Louisiana and your truck runs fine cold, you could leave the choke coil off.
~Steven
Simi Valley, CA
Old 01-08-2024, 11:40 PM   #15
murguia
Perfect, I’ll leave it off. I’m in cypress, CA.
Old 01-09-2024, 12:59 AM   #16
geezer#99
geezer#99's Avatar
If your choke blade is tied open then you can leave it off.
Old 01-09-2024, 10:25 AM   #17
Steeveedee
Steeveedee's Avatar
^ Yup! Or it could flop around and cause trouble.
~Steven
Simi Valley, CA
