Old 04-03-2020, 03:11 PM   #26
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Just Finished my Wood Bed
Looks great!! I love how you can see the cab in the reflection.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-04-2020, 08:53 PM   #27
Stover93
Very nice! How about some more pics of the rest of the truck!
Stover93 is offline   Reply With Quote
Old 04-04-2020, 11:43 PM   #28
57larry
very nice wood bed
57larry is offline   Reply With Quote
Old 04-05-2020, 12:10 AM   #29
basketcase
basketcase's Avatar
I like the walnut with the yellow. Very nice work.
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 01-08-2024, 11:28 PM   #30
Lico
Hello. What did you use to put the sealer down? Brush? Roller? Did you buff it out or that 400 grit was enough? Thank you in advance!
Lico is offline   Reply With Quote
Old 01-09-2024, 09:27 PM   #31
zicc1835
zicc1835's Avatar
this is a 3+ year old thread not sure if you will get a answer
I just finished my bed wood used some different products ill share with you I used a Mimwax oil stain named weathered oak and 5 coats of the oil based spar varnish applied with a sponge roller ( do not press hard on roller and stir the varnish DO NOT SHAKE so you don't get air bubbles...I sanded first coat lightly with 400 don't want to go through it and sand the stain then I used 400/ 600 the rest of the way ...this spar varnish will cause some yellowing the more coats you apply...I have another truck and bed that I will do when I finish this one and will try this product( last picture because it supposedly won't yellow) it is water based product if you are using a stain it must be water based also ....Brothers has some videos on the process too
zicc1835 is offline   Reply With Quote
Old 01-09-2024, 10:22 PM   #32
72c20customcamper
72c20customcamper's Avatar
I used Minwax water based spar urethane . 7 coats lightly scuffed between coats with 220 . Let the last coat cure for two weeks then wet sanded with 2000 paper and a light buff.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-09-2024, 10:32 PM   #33
zicc1835
zicc1835's Avatar
looks really nice no stain ? natural wood ? oak? ..curious what did you apply with ?
Old 01-09-2024, 11:01 PM   #34
Lico
Thankyou for the responses!!!
Old 01-10-2024, 12:11 AM   #35
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Way too slick for hauling Looks great.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-10-2024, 02:44 PM   #36
72c20customcamper
White oak that was milled locally no stain involved as I wanted the natural color to show through and the reason I used water based doesn’t affect the color . First three coats were done with a brush last few were done with a smooth finish small cabinet roller . Last coat was done with a foam brush .
Have to add this was the second go around with the wood . I had done it with Penofin marine oil . After a few months I took the wood back out planed it down a fraction and redid it
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-10-2024, 11:35 PM   #37
zicc1835
zicc1835's Avatar
thanks for sharing very nice outcome I know its a lot of work/time put in but great results thanks for sharing
jess
Old 01-11-2024, 01:49 PM   #38
BRL
BRL's Avatar
Just clicked on this thread and that looks really nice!
BRL is offline   Reply With Quote
Old 01-12-2024, 11:07 AM   #39
72c20customcamper
I’ve had plenty in the bed . Pop ups coolers and chairs for shows but I put the rubber non slip liner in it then a moving blanket. Found that with the glossy surface and polished strips everything shifted in the bed without the rubber . This is what I used
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 01-12-2024, 10:59 PM   #40
zicc1835
zicc1835's Avatar
great Idea....
