Mudslides 'r my specialty
How do I reinstall the LCA bumpstop?
When I changed out my coil springs, I inadvertently pulled the bumpstop out of the lower control arm...I can't get it back in. I push, but it just "squishes."
I tried "lubing" it with silicon spray...didn't work. Can anyone help?
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
If I remember correctly, it fits into a slit in the control arm. You install it by sliding the retaining tab into the end of the slit (a wider cut in that location) and slip it in.
I don't remember seeing that, but I will look again. Thanks.
A little lubrication and a set of pliers gently working the rubber tab as it sticks through the LCA slot was sucessful for me.
Mike |
