#1 | |
Conversion Truck Addicted
Steering Shaft upgrade XJ or Astro Van?
Im Rebuilding the front end on my C30 Im looking to replace the worn out rag joint and rubber isolater on the top as it worn out
I was looking into buying a XJ steering shaft but i came across this post thats seem that Astro Van shaft are about the same length and couplers too? https://www.thirdgen.org/forums/engi...astro-van.html Anyone know if an Astro shaft will work, they are commen in my part of the world weres the XJ is not, Shipping over seas are expensive so if i can get one local to me it I would save alot
Thomas Quote:
chevy truck fan
Re: Steering Shaft upgrade XJ or Astro Van?
GMTgmt, I did the XJ shaft conversion on my '86 (it is shown in my build thread on here) I am happy with the result, there is a thread on how to do the conversion on here and I THINK it discusses the astro shafts in there as well.. overall I think the swap is worth it.
#3 | |
The re-clocking requires cutting & re-welding of one end which is not required for the XJ swap.
#4 | |
Thanks, I got a shaft from a astro on the way, just and sleve it is not a problem so i will se if it can be made to work
Thomas Quote:
If you can, come back and let us know how it goes. It would be interesting to find out if that's an easily workable option.
I used a jeep shaft. One tip I would give is make sure you heat the plastic that locks in the slip shaft enough that the shaft freely moves in and out. Theres enough flex between the cab and steering box to cause popping if you leave it as a tight fit to adjust the length (even with liberal lube on it). In the end, I ended up knocking all the plastic out (there isn't much of a second chance). Definately an improvement over the rag joint, and even with no plastic to take up the "slop" in the slip shaft it is still miles ahead of a rag joint.
| Bookmarks |
