![]() Join Date: Oct 2012
Re: One piece windows
Thanks for the updates on the installs. The mixed results is what I've seen from all my lougle searches as well.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#2 | |
I ended up having to pull the window regulator out, then take out the screw on the bottom of the front channel, and then insert the window, and slide it up and down several times to see where it would move the easiest. Had to redrill the bottom hole for the screw. I also added a riv-nut to the top of the back channel. Yes, it lays against the door latch, with a gap...so I drilled a hole in the channel, and installed the riv-nut from inside the channel, towards the door latch. (Bottom portion of riv-nut pointing towards the door latch) Inserted the stock screw, and tightened up. Way more sturdy, and less flopping around of the glass.
"If it ain't broken, fix it 'till it is!" |
I am not going to lie, the glass is a pain to get in, but once in and the front channel is bolted in tracks very smooth and no binding. Initially I had a binding issue, but that was in the sash adjustment. After taking the sash out and adjusting the glass in the sash all was good. I will also say it is not easier on the second window, it averaged 1.5 hours with regulators and adjustments to install each side, regular glass and vent windows are a few minutes job. As I stated before, it is much easier with doors removed as you can get to the lower bottom bolt and the trique latches actually made the upper rear bolt easier to do. I tacked a 1/4-20 nut to backside of the upper track similar to what the factory did to ease installation of the upper track on around the latch. I can go into more detail but it really is a feel your way through it type of install. Still say it is worth it but you will definitely have a time investment.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
71 super can you explain your window sash adjustment, or provide a link to watch so I can try this?
As mentioned before, I didn't get instructions with mine, but if they are the same as the pictures on Vanatta Fabrications site, I have looked at those too. Thank you for any help.
