Old 01-17-2024, 01:17 PM   #1
jmartinezi@msn.com
Wheel/ Tire Combo
I have a 67 C10 with stock rear/ front end components. I plan to add 2/4 or 3/5 drop to it and add 20 x 9.5 rally wheels. I would like to see what wheel/ tire combo will not rub?
jmartinezi@msn.com is offline   Reply With Quote
Old 01-17-2024, 03:43 PM   #2
Jason Banks
Jason Banks's Avatar
Re: Wheel/ Tire Combo
Can you post a link to what wheel you are going to use? We need to know the backspacing and offset to get you close.
My go to with 20's on a 10 inch wheel are 295/40R20. But, the backspacing is important. It's highly likely you will need a spacer.
Jason Banks is offline   Reply With Quote
Old 01-17-2024, 03:56 PM   #3
Hawkynz
Hawkynz's Avatar
I am running 20x10 rear and 20x9.5 front with drops. Rear tires are 295/40R20 and front is 245/45R20. The rear is about max width I would run. I have about an inch both inside and out from the bed. The front will rub on the fender if you autocross it aggressively, but not bad.
Hawkynz is offline   Reply With Quote
Old 01-17-2024, 04:29 PM   #4
jmartinezi@msn.com
Wheels: 20 x 9.50 offset 20, BSM (in):6.08
https://www.visionwheel.com/wheel/47...5%2D2983GMML20
Tires: 245/45R20 103Y B BFG (Front), 275/40R20 106Y B BFG (Rear)
Old 01-17-2024, 04:33 PM   #5
jmartinezi@msn.com
Hawkynz, did you need spacers?
Old 01-17-2024, 06:36 PM   #6
Jason Banks
I would bet the wheel would rub in this situation. 6.08 inch backspacing is too much.
You can take off a rear wheel and measure from the inside surface of the wheelhouse to the front surface of your rear drum(or disc). It is probably not 6 inches(or very close).
Look at this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=646815
Post 5 - jmking9 has the wider rear end than you do. By .75 inch. He say she has 5.95 backspacing on 9.5 wide wheels and it is very close to rubbing.
For the narrower rear end this equates to 5.95 - .75 for a total of 5.2 inch backspacing almost rubbing. There's lots of threads on this. I found one where I said for a 9.5 wide wheel one the narrow dif, 4.25 might be maximum backspacing.
Old 01-17-2024, 08:20 PM   #7
jmartinezi@msn.com
Question Re: Wheel/ Tire Combo
So would I need spacers in a situation like this?
Old 01-17-2024, 09:04 PM   #8
weq92f
weq92f's Avatar
With stock '67 12 bolt, running 20x9.5, 5.5 offset, I needed a spacer to keep from rubbing inner fender/bed. The drop is 4/6 or so.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 01-17-2024, 10:05 PM   #9
LS short box
Pic of my 68. 4/6 drop.
285/40 and 255/40. 9" Rambler wheels in the back. 8" in the front.
Old 01-17-2024, 10:35 PM   #10
Jason Banks
LS Short Box. I looked at all the Rambler wheel diameters and only saw wheels that are 9.5" wide except the 22" and your don't look like 22's. Which one exactly do you have?
20X9.5 5X127 5.29backspace
18X9.5 5X127 5.29backspace
22X9 5X127 5.04backspace - But those sure don't look like 22's
Another thing. Are you positive you have the narrower 1968 rear end? i had a 1968 but swapped in a 1972 rear end so I could fit off the shelf wheels easier. I had a US Mags wheel that was 20X10 5X127 5.54backspace and with 295/40R20 it was so close to rubbing. Your tires look like they are just as far out as mine were.
Old 01-17-2024, 10:35 PM   #11
Jason Banks
Best bet is to measure. But I bet a 1 inch spacer would get you real close...
Old 01-18-2024, 03:13 PM   #12
HalfBrit
If you wind up using spacers, US Wheel Adapters make a quality product. I have 1/2" hub centric spacers on my '70 C10. Here's a link:
https://www.uswheeladapters.com/
HalfBrit is offline   Reply With Quote
Old 01-18-2024, 07:47 PM   #13
CC69Rat
CC69Rat's Avatar
I usually do a 4.5/6 drop
On a stock 67 rear housing I do a 20x10, with 5" backspacing. 295/40r20. 295/45 will work, but it's tight.
On the front, 20x8 or 20x8.5. 4.5 or 4.75 backspacing. 255/45r20.
*The critical thing you want to measure the rear housing. From the inside edge of one rear brake backing plate over to the other side in the same spot. If this measures 55.5", you have an early rear housing (before mid year 69) if the measurement is 57" you have a later rear housing and the specs above won't work.
If it's a late housing, I do a 20x10 with 5.5" - 6" backspacing. It just depends how low you drop your truck.
*** everything above assumes you have a fleetside truck. If you have a stepside, it's completely different ***
Hope this helps.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 01-18-2024, 07:53 PM   #14
CC69Rat
CC69Rat's Avatar
4.5/6 - static. Square body front Kmember. (85 Silverado F44 1.25)
20x10 - early housing. 5" BS. 295/45r20
20x8.5 - 4 3/4 BS (if I recall) it has been a while. 255/45r20
Chad
