Old 01-18-2024, 10:24 PM   #1
Accelo
Accelo's Avatar
firewall for the 4x4 vers 2x2
suburban posted this:
"As a side note the firewall for the 4x4 is different from the non 4x4".
Can anyone explain the differences?
Accelo is offline   Reply With Quote
Old 01-18-2024, 10:33 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Re: firewall for the 4x4 vers 2x2
there is no difference in the firewall, just all 4x4 cabs are high floor hump but a 4x2 with a big block is a high hump also. i put a 71 2wd cab on my 69 4x4, just had to cut the floor for the high hump. factory bucket seat cabs from 69-72 have the mounting plates for the buckets welded underneath. 71 cabs have the raised boss in the roof for the rear view mirror. if i remember correctly 67 and maybe 68 cabs have some differences behind the gas tank.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 01-19-2024, 12:22 AM   #3
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Also any 4 speed truck had the high hump. My 68 was a factory high hump but a 292 I6/4 speed
67 firewalls are unique as the recess for the motor in the middle is smaller overall due to no factory big block option. The modified the firewall in 68 to clear for a big block on the passenger side.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 01-19-2024, 09:40 AM   #4
Correct. No difference. You've been misinformed. The K-model engines sit back tighter to the firewall is the difference in motor mount locations
