![]() Join Date: Sep 2017
Re: Ol' Blue
![]() Started taking the Cameo apart. All the bolts are rusted, as to be expected. I spent all day getting the remaining bed wood out, leaving the side rails bolted to the crossmembers. HOW do you get those bolts out without damaging the sides? The side rails are straight and not rusted through and so I'd like to keep them. However, I can't drill the bolts out, they are too rusted to get the nut to come off, but not rusted enough to just break them, and that brings me to grinding them, but even the small air grinder with a cut off wheel is a little too close to the side. Ideas? ![]() Also, there are two things on each side, front and back, they look like an L shaped U channel that is flush with the top of the frame. If you look close at the picture, just behind the crossmember, and I think you can make it out. There is one on each side, and one more on each side at the next crossmember. What are they for and do I need them? Thanks.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 Last edited by 8man; 01-21-2024 at 05:52 PM. Reason: More details |
