01-22-2024, 10:19 AM | #32 |
Re: '50 3600 re-do. Shortening things up!
I've been scratching my head trying to figure out where the puddle of brake fluid was coming from on the drivers side around the front wheel. All the lines were checked & double checked & after closer inspection it appeared that it was coming from somewhere around the master cylinder so I set up me camera to see what happened when I applied the brakes and was shocked to see that the pressure switch on the proportioning valve was gushing fluid, not from the threaded connection but from around the front section by the plug. Somewhat surprised that this would fail especially since it's new.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
