Old 01-22-2024, 08:44 PM   #1
Rich1972C20
Pulleys for a Long Water Pump
I have to replace my stock short water pump with a long water pump for clearance for a Cloynes timing cover that I needed for my roller cam.
I am anticipating that I need different power steering pully (and/or bracket), water pump pulley and alternator pully (and/or bracket) so that the belts line up. I don't want to pay for an aftermarket serpentine system but rather use stock pulley/brackets.
Does anyone have photos of what will work and who might sell them?
Thanks guys
Rich1972C20 is offline   Reply With Quote
Old 01-22-2024, 10:17 PM   #2
tutone
tutone's Avatar
Re: Pulleys for a Long Water Pump
Find a 305 or 350 sqarebody engine fully dressed. They used lwp pulleys and brackets.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1969 C10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5
tutone is offline   Reply With Quote
Old 01-22-2024, 10:21 PM   #3
Mike C
Mike C's Avatar
I would ditch the aluminum cover or see if you can get it machined down. I hate long water pump conversion in a 67-72 swapping sides with alternator and AC compressor. The power steering pump brackets are completely different. Some of the serpentine setups had the accessories on the correct side so if you have to go LWP, that’s what I would be looking for.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
