![]() Join Date: Jan 2009
WTB 68 sb cast iron 3 grove water pump pulley
As above. For 67-68 with 327 factory air and power steering. Cast iron and 3 grooves. Shipped to Montana. Any help appreciated.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: WTB 68 sb cast iron 3 grove water pump pulley
I have this 3- groove short waterpump pulley if you can’t find the correct cast iron pulley.
I believe that a steel stamped pulley will work (not claiming this one will/wont just sharing information). Now the clutch fan from a 65-67 has a shorter stem and is a different part number tha 68 up because the cast pulley is much thicker. The 68 up sbc fan is much more common to find though so it depends on how original you want to be. Just sharing
Hoping to find an original cast pulley. Thanks LL99 and Chewy for the help.
![]() Join Date: Jun 2000
If you find one, I would like to see it. I've never seen a cast iron water pump pulley, Seen plenty of cast iron crank and power steering pump pulleys. My question is why do you need a 3 groove? The only time I see 3 groove water pump pulleys is when the engine has A.I.R and A/C. Power steering doesn't use the water pump pulley. Just wonder.
#6 | |
I thought this pulley stopped in 1966 but I could definitely be wrong. My pulley I posted is for the A.I.R. Pump engines with P/S and A/C. I consider it a rare waterpump pulley to find.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-12-2022 at 10:29 PM. |
Thanks for all the input. Chewy has a 3 groove cast wp pulley on his 68/327 air, ps and a.i.r. I've got a pic but don't know how to post it. Maybe Chewy will chime in and post it.
Here's the one from my 67 327 engine. I'll post some pictures as well.
Thanks for the pictures, I would have lost that bet LOL
I have one of those 3 groove 3868559 cast pullies. I am looking for the 2 groove 2995646 AH and the lower 2 groove 3744043 BA in great shape.
"Trucks with Class"
![]() Join Date: Jul 2000
Wow. That is all confusing. Not sure what anyone wants. I have a few stacks of pulleys too.
What is confusing? OP is looking for the cast 3 groove I have one. I also am looking for 2 pullies that I posted would trade. But it's an old thread.
I picked up the 3 groove pressed steel pulley and it seems to line up with my other pulleys. Would trade for the cast pulley....but I don't have the pulleys he needs. Thanks.
72 Cheyenne C20 BB, air 70 Suburban 20 BB, air, buckets 68 CST C20 air, buddy buckets |
