Old 01-26-2024, 04:48 PM   #1
Sicklajoie
The Niner
Sicklajoie's Avatar
Flood Penetrol as a clear coat
Thursday night's project with the Bomber was putting some kind of clear coat over the tired old paint.
Super impressed with how Penetrol works.
Makes the paint really pop and works well on the black trim too.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 01-26-2024, 05:14 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Flood Penetrol as a clear coat
Which pics are before and which are after?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-26-2024, 05:18 PM   #3
Sicklajoie
The Niner
Sicklajoie's Avatar
Here's a before.
Old 01-26-2024, 06:01 PM   #4
RichardJ
Wood Paint?
I would expect checking and crowsfeet within weeks. Maybe longer out of the sun.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 01-26-2024, 06:33 PM   #5
72c20customcamper
72c20customcamper's Avatar
Originally Posted by RichardJ View Post
Wood Paint?
Not paint it’s basically linseed and some other additives.
“Penetrol is a product of linseed oil mixed with a few other ingredients. Penetrol is essentially a product of linseed oil, long oil alkyd resin, and Stoddard solvent”
BLO has been used forever to protect outdoor tools
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-26-2024, 06:35 PM   #6
truckster
truckster's Avatar
It looks nice.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 01-27-2024, 04:28 AM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Every 6 months ish.
Old 01-27-2024, 10:15 AM   #8
70STOVEBOLT
Does it feel like there is oil on the paint after it’s applied or is it more like wax?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 01-27-2024, 10:56 AM   #9
Sicklajoie
The Niner
Sicklajoie's Avatar
It's definitely oily, you hafta let it cure for 12-24 hours.
Old 01-28-2024, 11:07 AM   #10
un4gvn!
un4gvn!'s Avatar
I painted houses for the last 40 years. I add this to all my oil base paints to slow down drying time and it helps to flow the paint out. I use it on interior trim and you sware I sprayed it on where I use a quality oil brush. Latex paint you would use Floetrol.
un4gvn! is offline   Reply With Quote
Old 01-28-2024, 06:26 PM   #11
Rust_never_sleeps
Rust_never_sleeps's Avatar
I wondered about this, Floetrol is magic.
Would you use Japan dryer to force a complete cure of oils/varnishes, or does that defeat your drying time+flow? I only know of it from woodworking, and maybe it's an antiquated concept
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 01-28-2024, 07:59 PM   #12
un4gvn!
un4gvn!'s Avatar
The big problem with using Penetrol right out of the can is it does NOT have uv protection or salt protection. It's not a sealer. It's a paint conditioner. Works great for wood primers as it slows down drying time to allow the primer to penetrate deeper. Works great with oil base paints to allow it to flow out smooth. I used it for years. Still do. Same with Floetrol for water base paint. I have to wonder what the truck will look like in the spring. When the time comes to get a real paint job, will the Penetrol be an extra paint prep step to remove?
Old 01-28-2024, 08:25 PM   #13
KQQL IT
At the body shop.
KQQL IT's Avatar
Mine gets kinda flaky after awhile. Pressure wash scuff and retreat it.
I just washed it, when it's dry I will get a flake pic
Old 01-28-2024, 08:31 PM   #14
Sicklajoie
The Niner
Sicklajoie's Avatar
In no way shape or form is this truck getting another paint job.
Old 01-28-2024, 08:45 PM   #15
KQQL IT
At the body shop.
KQQL IT's Avatar
Flaking.
3/4 months in the weather.
Old 02-01-2024, 07:06 PM   #16
Sicklajoie
The Niner
Sicklajoie's Avatar
Rolled her outside today, pretty happy with the way it turned out.
Old 02-01-2024, 07:56 PM   #17
54blackhornet
54blackhornet's Avatar
You can also use Thompson Water Seal.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
