Old 01-23-2024, 11:31 PM   #4551
novaX522
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by MS66 View Post
What paint did you use? Several years ago Dupli Color had a paint called Steel Wheels (WP316) that looked great on rally wheels, it was discontinued long ago. Before I found that paint, I used a silver metallic paint off the touch up paint rack. It was GM van and truck paint, can't remember the number on it, but it looked good on ralleys too. Haven't painted ralley wheels in a long time, need to redo the ones on a couple square bodies, just haven't been motivated with the cost of paint these days. That can of touch up paint was less than $5 back then, it's $17 now.
Here’s the paint I used.
novaX522 is offline   Reply With Quote
Old 01-23-2024, 11:33 PM   #4552
novaX522
It’s $12.50 a can. Like everything else, outrageous.
In spite of the cost, I do like the paint.
Old 01-23-2024, 11:34 PM   #4553
novaX522
Old 01-24-2024, 12:04 AM   #4554
MS66
MS66's Avatar
Originally Posted by novax522 View Post
it’s $12.50 a can. Like everything else, outrageous.
In spite of the cost, i do like the paint.
10-4.
MS66 is offline   Reply With Quote
Old 01-26-2024, 12:56 AM   #4555
Danyo492
Painted the frame for my 67 C10 tonight. Uses Sweet Patina’s “Black Out” frame paint. Brushed it on and pretty impressed with the finish and how well it laid down.
Not sure why my photos are uploading turned like that. Apologize in advance to your necks lol
Danyo492 is offline   Reply With Quote
Old 01-26-2024, 11:12 AM   #4556
LNP
Looks nice!
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 01-27-2024, 11:06 AM   #4557
Extended Power
Extended Power's Avatar
Cut, and modified the shift lever that came with the CPP tilt column, so I could use the new billet shift lever.
Polished it up nice.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 01-27-2024, 11:08 AM   #4558
Extended Power
Finally got around to installing the billet door handles.
Went with the brushed look, as it’s easy to “fix” any scratches or other rub marks...just use a piece of scotch brite.
Old 01-27-2024, 09:26 PM   #4559
Extended Power
Used Velcro to stick up the headliner I bought a few weeks ago.
After watching the video of the install from Brothers Truck, I didn’t wanna cut slots in the cab for all clips...plus, seeing the results on here from others who installed theirs without the trim, I thought it looked cleaner too.
Old 01-27-2024, 10:49 PM   #4560
Steeveedee
Who Changed This?
Steeveedee's Avatar
Looks nice from here! I bought the trim because mine came factory with the headliner. I had to plug the holes with something!
~Steven
Simi Valley, CA
Old 01-28-2024, 12:00 AM   #4561
Extended Power
I bought the trim too....but now it’s just gonna get tossed onto the pile of unused parts.
I’m sure the trim can still be installed...would just have to be super careful making the slots.
Old 01-28-2024, 03:33 AM   #4562
BRL
BRL's Avatar
Originally Posted by Danyo492 View Post
...Not sure why my photos are uploading turned like that. Apologize in advance to your necks lol
HA!
I posted a thread in the general discussion section concerning that same issue and someone suggested that I crop the picture a little which did the trick for me.
Got my instrument cluster back in after adding my new cheap $20 Amazon tachometer.
I would like to reduce the brightness a little and the tach allows that by pushing a little button on the tach face, but that is behind the original plexiglass lens now and I don't want to drill even a little hole in the original lens to dim it.
Overall I'm pleased with how it all came out and I'll quickly get used to the brightness.
The red ring on the tach is due to the red needle reflecting off of the chrome bezel hole cutout if that makes any sense.
BRL is offline   Reply With Quote
Old 01-28-2024, 09:34 AM   #4563
Jiggers72-GMC
Jiggers72-GMC's Avatar
EP, the headliner looks great.
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 01-28-2024, 01:45 PM   #4564
PowerdbyChevy79
PowerdbyChevy79's Avatar
That looks good... Do you have to top coat it?
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 01-28-2024, 02:04 PM   #4565
Extended Power
Wifey helped me install the factory GMC, paint matched tailgate.
I have all new trim to go on it, but I'll leave that to the bodyshop guys.
I bought this tailgate for $50.00.
Couldn't get the $50 bill out of my pocket fast enough to pay the guy.
Picture me running towards the wife's truck while carrying this tailgate yelling, "START THE CAR, START THE CAR!!!"
Old 01-28-2024, 02:11 PM   #4566
Extended Power
Gonna use the old tailgate for the backrest of a bench for the yard.
Old 01-28-2024, 02:30 PM   #4567
68bowtie
68bowtie's Avatar
Wow! Nice
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 01-29-2024, 12:04 AM   #4568
novaX522
I ordered front and back rear wiring harnesses from LMC. I untaped the back harness and soldered on wires for the 7 pin connector and taped it back together. I also cleaned the bulb housings and fixed the wiring going to them. I got all the lights and turn signals working. The brake lights are not working. I will troubleshoot the brake switch tomorrow.
Old 01-29-2024, 11:06 PM   #4569
novaX522
Brake lights not working so I got my meter and tested the brake switch and it is good. I measured 12v on the orange wire and jumpered it to the white wire and still no brake lights.
I had no idea where the white wire went. Thankfully I downloaded the wiring diagrams from this site. I was able to trace the white wire to a half moon shaped wire connector where I found the wire wasn’t making good contact.
Got it fixed and have brake lights now!
Old 01-29-2024, 11:07 PM   #4570
novaX522
Old 01-30-2024, 06:43 AM   #4571
BRL
BRL's Avatar
Originally Posted by BRL View Post
...Overall I'm pleased with how it all came out and I'll quickly get used to the brightness...
I would have just added this message to my previous post but I don't know how to add pictures to an edit.
Hey I'm just glad the dang pictures aren't coming out sideways anymore.
Many years ago I added some cheap tachometer guts to my guage cluster but eventually the thing died.
It also stood out brighter than my other gauges and that was never a problem, so this new cheap tachometer brightness shouldn't be a problem either.
Come to think of it, the old one was probably long since dead before I even noticed.
So how many of you have run out of gas before you even noticed that big ol' fuel guage was sitting on empty...
I rest my case.
Old 01-30-2024, 06:48 AM   #4572
BRL
BRL's Avatar
Originally Posted by novaX522 View Post
... Got it fixed and have brake lights now!
Awesome!
Old 01-31-2024, 01:44 PM   #4573
OregonNed
OregonNed's Avatar
Aligned my rear bumper and tucked it in as close as I could with the stock brackets..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 01-31-2024, 11:19 PM   #4574
pjmoreland
pjmoreland's Avatar
I acquired this original bezel with very little sun fading in the paint out of a '68 and installed it in my '68.
pjmoreland is offline   Reply With Quote
Old 01-31-2024, 11:57 PM   #4575
BRL
BRL's Avatar
Nice bezel!
