Old 11-29-2023, 02:59 PM   #51
Shifty One
Shifty One's Avatar
Re: BUILD: 1970 C10 LWB “Jumping Cholla”
Originally Posted by loudchevy View Post
And never let go! Needle nose pliers work best to remove them.
Or have a friend that is an absolute magnet lead the way, and clear them out for ya!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 12-06-2023, 11:58 AM   #52
Chaparralman1974
Chaparralman1974's Avatar
After a lifetime living in the AZ desert and 20+ years of mountain biking, I have actually found either a fork or a metal comb to be essential in getting cholla out! I hate that plant and wish it could be totally erradicated from the face of the planet! LOL
In all seriousness, Scott you are doing a fantastic job and at a record pace! That is going to be one sexy truck when you are done!
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20 "The Town Truck"
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is online now   Reply With Quote
Old 12-06-2023, 12:10 PM   #53
loudchevy
loudchevy's Avatar
Clay
Thanks, Clay! Progress has slowed a bit the last month, but I'm getting ready to jump back in and make some more progress.
Scott
1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 12-07-2023, 12:00 PM   #54
rodstored-72
chevy truck fan
rodstored-72's Avatar
LOL!! I see what you did there! ... agree nice progress!
rodstored-72 is offline   Reply With Quote
Old 12-15-2023, 10:20 AM   #55
Stickman
Stickman's Avatar
LOL , cholla, hate it and great work by the way.
Stickman is offline   Reply With Quote
Old 12-18-2023, 04:49 PM   #56
Tip70
Tip70's Avatar
Nice work! Trucks turning out great!
1970 C/10 SWB
build thread:
https://67-72chevytrucks.com/vboard/...d.php?t=847860
IG- Tip70
https://www.etsy.com/shop/Tip70Designs
Tip70 is offline   Reply With Quote
Old 12-18-2023, 05:52 PM   #57
loudchevy
loudchevy's Avatar
Progress is slowly moving along. The holiday season is definitely taking up garage time and I've been NOT looking forward to cleaning the cab up and getting the last bit of 50 year old crud off the C10. My 700R4 (snowman) is back in my garage with its new 2wd output and a fresh rebuild with all the goodies. I was just going to get the builder to swap outputs but he tore it open and found a few things to upgrade so might as well do it now than later.
First thing I wanted to do was build a new cab stand to replace the quick and easy wood cart I built a few months ago to work on the rockers. This version is made of some 2" square tube and bolts to the cab mounts. It's much more stout than the wood version. I left an extra foot on the end rails so I could lift the front firewall and use the rails as a pivot to stand the cab upright to gain access the the bottom of the cab. With this new stand I can rotate the whole cab 90 degrees by myself. I just throw 2 pallets on the ground and tilt it back. Worked out perfectly.
I started scraping junk off the bottom yesterday and got a decent amount done and cleaned up. I only took a pic of the results of the first 20 mins of scrapping. In some spots the crud was 1/4" thick.
Scott
2003 Tahoe Stock
Old 12-18-2023, 05:53 PM   #58
loudchevy
loudchevy's Avatar
Thanks!
Scott
2003 Tahoe Stock
Old 01-15-2024, 10:01 AM   #59
loudchevy
loudchevy's Avatar
Slow moving the last month or so on the C10. Been stripping old paint from the cab, core support, and wheel wells. It a slow dirty process using a SCT and a hand grinder. I got the majority of the cab, core, and wells cleaned up. I didn't remove all the interior paint on the rear cab and ceiling. It's really not in terrible shape so I might just sand it and spray my primer over it. All the other smaller and hard to reach areas of the parts will be cleaned up with a sand blaster. Overall there is zero to no rust on the cab (all of the rust was removed when I did the rockers and adjacent floor). I plan on spraying this myself (it will be my first paint job) and I wanted to get the wheel wells cleaned up so I use those as practice before spraying the cab. Once primed, I'm gonna hit the under cab with some Raptorliner. I saw Chaparralman1974's cab with the raptor sprayed on and it looked great so I'm going to run with it as well. After cleaning up the core support, I removed the "pinch" folds on the top rail of the support. I cut some of the material out and hammered down the pinch for a nice clean look. I hope to get the cab in primer/raptor by the end of the month.
Scott
2003 Tahoe Stock
Old 01-15-2024, 10:05 AM   #60
loudchevy
loudchevy's Avatar
Here is a couple pics of the cab.
Scott
2003 Tahoe Stock
Old 01-15-2024, 11:19 AM   #61
clay68c10
clay68c10's Avatar
Nice work. My hands get tired just looking at those pics. That is a tough job.
I may do the core support pinch smoothing too.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-15-2024, 11:36 AM   #62
loudchevy
loudchevy's Avatar
Thanks, those pics contain hours and hours of work.
The core support shave was super simple. I always hated seeing those pinches on the top rail when looking under the hood of these trucks.
Scott
2003 Tahoe Stock
Old 01-15-2024, 11:50 AM   #63
raggedjim
raggedjim's Avatar
Nice work, I have a core support that I want to remove those from also. I'm also thinking about lowering the support ribs in the front to allow me to use a filler panel between the support and grill.
raggedjim is offline   Reply With Quote
Old 01-15-2024, 12:49 PM   #64
Stickman
Stickman's Avatar
Nice work, makes my back hurt looking at some of the pics !
Old 01-29-2024, 11:44 AM   #65
loudchevy
loudchevy's Avatar
Progress update....Spent the last 2 weekends stripping body panels and parts. Last weekend I started on the front quarter panels and cowl. I picked up Harbor Freight's sandblaster to get all the hard to reach areas that my 4.5" stripping disc and wire wheel couldn't get. It actually worked very well. I used the fine media from Tractor Supply after putting it all through a strainer to remove some of the larger chucks to not clog the nozzle. I got the wheel wells, cowl, and the fenders all stripped and then spent hours sanding those and the core support to get ready for some Epoxy primer. I plugged the antenna hole and some 16 other screws holes that he PO had put in the sides of the cowl (I think they had dual CB antennas mounted, but that is just a guess). I also filled the holes for the trim molding on the front fenders. I'm not a fan of trim molding on my trucks, I always rip them off when I get a new truck. I actually have all the pieces for this C10, but they're all beat up, dented, scratched and the black paint is faded. I also got the seat sliders, hood hinges, and front core/grill brackets blasted and cleaned up too.
The cab still needs more work. I have some areas to still clean up, holes to fill weld, and sanding lots of sanding.
Scott
2003 Tahoe Stock
Old 01-29-2024, 11:51 AM   #66
Chaparralman1974
The truck is looking great Scott! I am looking forward to seeing it in person. Are you going to raptor line the inner wheel wells? I am thinking about doing that on mine.
Clay
Clayton Sikes
Peoria, Arizona
Old 01-29-2024, 12:02 PM   #67
loudchevy
loudchevy's Avatar
After spending Friday night and all day Saturday cleaning parts, Sunday (yesterday) was time to prime. I had never used a paint spray gun before so this is my first attempt at painting. I'm not gonna lie I was pretty nervous about it. My wife had a good point while I was telling her this, she said "If you mess it up, just strip it all down again LOL" I started out with the wheel wells to "practice". I am using the A610 LVLP spray gun. I've watched hours of YT videos of people using this LVLP gun with success, so I figured I would try it before I dropped a ton of money on a HVLP gun. I was really surprised how easy the process way. First coat went on wheel wells great! I gave it 30 mins of flash time and applied the second coat. I think I didn't add enough hardener to the mix, because the second coat on the outside of the wells took forever to dry. While I waited for the outside of the wells to dry, I got the core support covered in 2 coats, making sure to add just a little extra hardener in those mixes. The core dried faster than the wells. Overall I was super happy with how the 3 pieces came out and it gave me the confidence to continue learning the new skill of painting. I burned through 2 quarts of the Eastwood Epoxy for just these 3 parts. More epoxy is on the way!
Next parts to paint will be the fenders and cowl. Then I'll do the cab. I wanted some easy practice pieces before doing the cab. I know it will be a challenge to paint with all the surfaces in different planes
Scott
2003 Tahoe Stock
Old 01-29-2024, 12:04 PM   #68
loudchevy
loudchevy's Avatar
Clay
Thanks Clay!
Yes, I was hoping to get the raptor sprayed on the inners yesterday, but the outside of the wells took to long to dry and I ran out of time.
Scott
2003 Tahoe Stock
Old 01-29-2024, 12:06 PM   #69
MySons68C20
MySons68C20's Avatar
Looking great very nice work!!
MySons68C20 is offline   Reply With Quote
Old 01-29-2024, 01:54 PM   #70
Shifty One
Shifty One's Avatar
Excellent! Lesson: Don't fear the paint gun!
Old 01-29-2024, 03:36 PM   #71
loudchevy
loudchevy's Avatar
Thanks!
Scott
2003 Tahoe Stock
Old 01-29-2024, 03:37 PM   #72
loudchevy
loudchevy's Avatar
Not anymore. Grip it and rip it
Scott
2003 Tahoe Stock
Old 01-29-2024, 04:08 PM   #73
Shifty One
Shifty One's Avatar
Hell yeah!
Old 01-31-2024, 04:13 PM   #74
nicklear36
nicklear36's Avatar
Re: "BUILD: 1970 C10 LWB--->SWB “Jumping Cholla”
That's a lot of paint stripping Great work
nicklear36 is offline   Reply With Quote
Old 02-19-2024, 10:51 AM   #75
loudchevy
loudchevy's Avatar
Tons of progress the last few weeks. This past weekend was a great feeling of accomplishment. Along with the wheel wells and core support, I now have the front fenders, cowl, and cab in epoxy primer. The bottom of the cab still needs primer and Raptor liner, but that will have to wait until next weekend. It was a pretty good feeling enjoying a few beers in the garage staring at the grey cab. I still need to strip the hood and both doors, but I'm pretty happy right now. The cab and fenders are really straight pieces. The primer definitely shows where the dings are in the sheet metal but the 50 year old steel is in very good condition. Hopefully it all comes back together with minimal filler.
Scott
2003 Tahoe Stock
