Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 01-30-2024, 09:11 AM   #31
LockDoc
The Older Generation
LockDoc's Avatar
Re: The 'Burban Chronicles.....
Originally Posted by Average Joe View Post
Thanks for the input Leon. Any idea on why it was getting hot? Was it not returning fluid fast enough through the cooler? Slipping? Were you able to adjust when it shifted into OD or when the converter locked up? I may have to research controllers a bit more. Some of them have more adjustability than others.
It may have slowed down the fluid flow some but I think the overall high ratio was just putting too much stress on the transmission. It was not slipping. The leak coated the whole underside and back of the truck with transmission fluid. It was a mess..... The first indication that I had a problem was that I couldn't see out of the back windows in the rear view mirror because they were coated with transmission fluid.
The engine/transmission/computer/wiring were a unit as removed from the Camaro so no adjustment. I don't think that would make any difference in this situation anyway. I don't think you could adjust that problem out of it.
Leon
