New to this group 1970 Chevy K20
I知 new to this group I知 currently working on getting a 1970 Chevy k20 road worthy.
Re: New to this group 1970 Chevy K20
Yes I do but don稚 know how to post them
I'm trying....
![]() Join Date: Oct 2013
Welcome to the group. Great truck. Already posted in your brake drum thread. I'm working on a 70 K20 myself. I'm not yet ready to start a build thread, but maybe soon. You wouldn't happen to have a build sheet for that truck would you? I'd love to see it if you do.
This is a great site to be on. Lotsa helpful folks willing to lend a hand. I sure have benefitted from their kindness.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
Thanks! I知 not sure that I have a build sheet all I have is door tag, paperwork from the last previous owner and possibly the sticker inside the glovebox but besides that nothing else. No manuals nothing
I'm trying....
Some plants (mainly Fremont I think) were know for putting them in the seat springs and sometimes under the carpet (if equipped). Might be worth a look.
I'm trying....
Unless called out as different on your SPID, in '70 the stock gear ratio was 4.57 and is probably what you have.
4.10 is a possibility or 5.13. In 70, those likely had a SPID call out. Your SPID will tell you if you've got a locker. If you do, there's likely a metal tag on the diff bolts. The front Dana may have a tag too. If it does, it'll likely have the gear ratio on it. The front and rear ratios match. Of course if you pull the cover you'll be able to see the ring gear which has the ratio on it.
Ok thanks
I'm trying....
![]() ![]() Join Date: Jul 2003
Welcome! My grandfather purchased a 1970 K20 new, and it was rough but alive around 8 years ago.
My dad purchased my 1970 Blazer new and I am currently performing a frame off restoration on it.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
![]() Join Date: Aug 2013
Welcome ,
As the guys mentioned This is a great place to be My main residence is in CA But we have a summer home in Hull, MA My driver back there is also a 70 K20 Maybe we can hook up sometime this summer |
👍 do you have any front drums for sale for mine? I知 having a hard time trying to get them thanks.
#15 |
Born Psycho
![]() Join Date: Feb 2001
torque king 4x4 (406)384-0270 shows them, pretty pricey $283.98 each, thats the only ones i could find, hope it helps you.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
