01-16-2024, 01:09 PM | #1 |
Storing Front Clip
I just finished removing the front clip from my truck. I took it off intact. I have it stored in my garage in an upright position and sitting on the back of the fenders that normally face the door. It is heavier then I thought it would be. I am little worried that the weight sitting on the edge of the fenders might distort the fenders. I have set a goal for my build to take about a year to get the truck reassembled. Is that too long to leave the clip intact sitting upright with out effecting the fenders? Or, am I worried too much.
Thanks, Rob |
01-17-2024, 06:40 AM | #2 |
Re: Storing Front Clip
Are your inner fenders still attached also? If so, that would add some rigidity to all of it. As long as you can't see any tension/twisting on the fenders from too much pressure, it will probably be alright. Just my opinion.
01-17-2024, 11:25 AM | #3 |
Yes, the inner fenders are still attached. I tied it to some sturdy shelving next to hopefully prevent it from moving or anything like that.
01-17-2024, 11:12 PM | #4 |
I took the entire front clip off and completely apart when I replaced the radiator core support several years ago. My thoughts are that it's simple to disassemble and reassemble, so if you're worried about the fenders having issues, especially if there's some rust in the structure, you'll be better off taking it all apart. It will also give you the opportunity to address any rust issues if you desire to do that.
I only replaced the core support with an aftermarket piece, so I had no trouble at all getting everything lined back up properly. I just took my time and left all the bolts loose until I got everything lined up well.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
01-18-2024, 10:08 AM | #5 | |
That is a good point. There are a couple reasons I haven't taken it apart.... yet. First is storage. I am tight for space, so it is easier right now to store it in one piece. Second, my goal for the build is to get it back together and enjoy driving while I continue to work on it and fix things. So, my vision is to put it back on in one piece. Like most of our trucks, it does need rust repair at the bottom of each fender. I did find a bit of rust on the passenger side where it bolts to the bushing. It is not completely rotted so it could go back on as is. I think a lot of what I do with it will depend on time. Yes, it would probably better to fix things while it is apart now, but sometimes I am not very patient. |
01-19-2024, 10:10 PM | #6 | |
01-25-2024, 03:37 PM | #7 |
I left mine like that for a good year with no issues. Fit right back on when I was done.
1965 C-10 1/2 ton shortbed part time daily driver 1980 C-10 1/2 ton shortbed project |
01-26-2024, 09:44 AM | #8 |
01-31-2024, 12:29 PM | #9 |
My front clip is intact & sitting on a dolley w/some cardboard under the edges & I'm using ratchet straps @ each side to keep it from tipping. Been there for multiple years w/o issue.
02-01-2024, 09:52 AM | #10 |
Not sure what they are called but they are sort of a floor pad the fits together like a jigsaw puzzle. I think they are considered exercise mats. Either way, that is what I have mine sitting on. Thanks for the feedback. Sounds like it should be ok.
