#26 |
Active Member
![]() Join Date: Jan 2015
Re: Patina love
Picked up some of these from Napa this a.m. so I can redo all the engine compartment wiring when I install HEI. 2 bucks a pop what the heck haha
#27 |
Active Member
Re: Patina love
So I come home after a hard days work ready to take the dogs for a ride in “TETNUS”. And upon opening garage door I found this
![]() So I had to heat drums up with torch as they were siezed on axle flange. And then I race on down to O’Reilly to get parts. I bought new drum, pads, wheel cylinders, spring kits, adjusters, axle seals and axle bearing. All of which will be here tomorrow. When I get home I finish disassemble both sides and find the e brake cables broke. So I call orielly up and although they didn’t have them he gave me ac delco number 18p2299. Hope it’s right cause I got a pair coming second day from rock auto. What a mess. Lmao ![]() |
#28 |
Re: Patina love
Are you not running a rear coil spring?
1968 C10 327, 3 speed manual, LWB stock height daily driver. 1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon. |
#29 |
Active Member
Re: Patina love
#30 |
Active Member
Re: Patina love
Got the clutch fan installed
![]() Got three on the 🌲 bushings in ![]() HEI showed up ![]() Got a pile of brake parts to completely go through rear end Then I bought a sand blast cabinet to clean small parts ![]() |
#31 |
![]() Join Date: Dec 1999
Re: Patina love
I do not get the "patina love" thing. Two reasons to leave the body on my truck as it was in my build. I do not have the money to spend (understand that) or I have more dollars than cents (sense). I saved a lot of years to do my truck as I wanted. I will love it with the new paint. The original faded and rusted exterior would be a compromise to me. No matter what I did to fix it up it would still be an old rusty truck. Can the old rusty truck still be enjoyed, yes.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#32 | |
Active Member
Re: Patina love
#33 |
Active Member
Re: Patina love
Got some spare time today, pulled the axles and although the bearing look great the axle surface was pitted. So I got a new pair of 6 lug axles with bearing, seals and lugs on the way
![]() Then I pulled rear end , degreased and pressure washed. Then went to town with wire wheel. Already have everything new so getting it painted and re installed. Axles hopefully Friday. ![]() |
#34 |
Active Member
Re: Patina love
Also on my list of things to do. I need some help identifying my air cleaner. Is it oem? The lid is rotten where wing nut goes on top. So I’d like to find a complete setup for a 1 barrel that is era correct. Any help appreciated
#35 |
![]() Join Date: Jun 2002
Re: Patina love
Well, I do love the patina look. I like car shows but I LOVE junkyards and when I see a patina truck I'm happy someone loves it enough to keep it on the road. I'd rather see patina than billet and tweed.
Nice work, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
#36 | |
Re: Patina love
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 02-07-2024 at 02:30 AM. |
#37 |
Active Member
Re: Patina love
Building brake lines and assembling rear brakes at this point. Weather sucks here and painting parts is a total pain in the a$$…. Axles should arrive today, hopefully. And I got a package last night with a radio delete plate I had bought from a member. Here’s the before and after
![]() ![]() Late night picks I know but it helps clean up the dash and appearance so much it’s hard to explain |
#38 |
Active Member
Re: Patina love
More progress today
#39 |
Active Member
Re: Patina love
#40 |
Re: Patina love
You're going to have a nicely sorted out truck when done!
I'll look at my air cleaner stash and see if I have one I could part with... |
#41 |
Active Member
Re: Patina love
#42 |
Active Member
![]() Join Date: Sep 2023
Re: Patina love
your pics are huge may want to resize them before posting
#43 |
Active Member
Re: Patina love
#44 |
Active Member
Re: Patina love
Been having a full throttle stumble since I bought this truck a month ago. I flushed tank, installed eBay electric choke 1 barrel, installed new fuel pump, installed HEI along with the firewall to distributor rewire. Always starts like a champ runs smooth throughout throttle except for full throttle. Yesterday while getting parts at orielly it wouldn’t even click to start. So I used there battery jumper and got home to check. Low and behold the 3 wire alternator to a crap. So this a.m. I decided to install a 1 wire setup. Mostly for being simplistic and less wiring. So I bought a 61amp 1 wire, and ran new 10 gauge wire from alternator to starter post as I like to no clutter up battery. Thing runs the best it has ever ran. Wish I would have caught this early on.
#45 |
Active Member
Re: Patina love
Testing for smaller photos
#46 |
Active Member
Re: Patina love
Getting some three on the 🌲 action in today.
#47 |
Re: Patina love
You got it figured out now! Here's the difference illustrated (chrome browser zoomed out to 25% of normal size): -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#48 |
Active Member
Re: Patina love
#49 |
Active Member
Re: Patina love
On another note I got heater core/ heater hoses/radiator hoses, all new clamps, water pump, 195 thermostat, thermostat housing gaskets. Radiator going in tomorrow to get the rod out treatment hope it’s all good. Then reinstall and on to the next thing. lol. Everything I touch gets the full treatment of degrease, scrape, sand, wire wheel, primer and paint. Planning the Chevy orange treatment on the engine too
#50 |
Re: Patina love
I have an OEM 2 barrel air cleaner in good shape. I'm not sure if it will fit the single barrel though?
