Old 02-04-2024, 11:19 PM   #1
custom10nut
custom10nut's Avatar
Center of Balance?
Without getting too technical, where is the approximate Center of Balance on our trucks.
I have my own Two-Post Lift (properly bolted in) in my Shop, but I do everything by myself (unless my son is home on leave. ).
Getting vehicles centered left and right is easy,, with the tennis ball hung on a string, but my real concern is front to rear weight distribution.
It’s been a long time since I put my truck up on a two-post, and I don’t want to become a viral video on YouTube.
My truck is a LWB C-10 with wood bed, and 3950 curb weight.
If I remember right, the lift towers are centered right about at the door handles.
Am I right here?
I don’t need to be flipping my truck on its nose or stressing out my lift, because I picked it up off balance.
Thanks in advance
custom10nut is offline   Reply With Quote
Old 02-05-2024, 02:14 AM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Center of Balance?
Front near the front cab mount
And a extension on the front spring hanger.
Old 02-05-2024, 02:35 AM   #3
custom10nut
I’m not sure what you’re saying here.
C-10s don’t have a “Front Spring Hanger”. Do you mean an extension on the lift arms to clear the underside of the cab?
Also, I find it hard to believe there’s equal weight to the front a rear of the lead edge of the door.
When I was in the Army, the Center of Balance on our 3/4 ton pickups (AKA CUCV) was at the back edge of the cab.
Old 02-05-2024, 02:41 AM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
That is how I lift mine on a 2 post.
The frame near the cab mount. And front spring hanger of the rear leaf spring pack. Felt spreading the load as far apart as possible. I pulled up til the door opened easy for me to get out of the cab.
Old 02-05-2024, 03:28 AM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Sorry, I just realized our old blue has leaf springs your pickup may not
Old 02-05-2024, 07:37 AM   #6
Go with KQQL IT's suggestion and lift it 6" to test it out. If you need to do it differently, you can work it out at 6" off the floor
Old 02-05-2024, 04:04 PM   #7
weq92f
weq92f's Avatar
Once you're satisfied with the balance point, acquire and utilize those stabilizing stands (tall @ss jack stands for use under a lift), one at the front and one at the rear. This will give piece of mind and a few extra seconds if things go south.
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-05-2024, 10:26 PM   #8
custom10nut
Absolutely.
I still have to get two stands, but due to the declining health and death of my Father-in-Law, any work in the shop has been put on the “Back Burner”.
Not looking for sympathy, but I’ve put 34,000 miles on our DD in the last seven months.
I usually average 8-10k in a year.
Enough of that.
Thanks for all the great advice and tips
