Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 12-07-2023, 04:31 AM   #426
LT7A
Re: 1972 Medium Blue Highlander Blazer Resto
Enjoyed going back through this. Took a buncha notes. Thanks for the time you took to post all of this. I'd love to see more out and about pictures. Happy Holidays!
Old 12-07-2023, 03:37 PM   #427
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for the good words! I'll do better at posting some out-and-about pics. While garaged over the winter I need to remove the HEI and replace the pickup coil, which I believe is causing problems w warm starts. Have a Merry Christmas and Happy New Year all.
Old 01-30-2024, 04:25 PM   #428
72 paul
Say Pete,what might you have used for cushion on tailgate to hatch stop top of gate.Followed your restore missed it.Way cool work..Thanks for any reply.Paul..Double sided tape?
72 paul is offline   Reply With Quote
Old 01-31-2024, 03:27 PM   #429
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Great question. I had to think about this. If I recall, we used a non-hardening bedding compound along the seam of the tailgate strip. I'll take a peek and if I have anything else to add will let you know. Thanks for the good words. I've been battling the HEI and replacing the pickup coil is on my short list of to do's ahead of spring.
Old 02-03-2024, 11:10 AM   #430
72 paul
Thanks for reply Pete.Did use double side 3m tape, worked good.Hoping to have top back soon,back at painters to do touchup.
Old 02-03-2024, 05:18 PM   #431
DeadheadNM
Carpe manana
DeadheadNM's Avatar
You bet. I suspect that will work just fine. Good luck with remainder of the build.
Old 02-06-2024, 09:03 PM   #432
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Tempted to restore the original points distributor and ditch the HEI. 2B3 = 1972 (2) February (B) 3rd (3)
Old 02-06-2024, 09:23 PM   #433
IronCanine
I'm trying....
IronCanine's Avatar
Do it!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 02-06-2024, 10:04 PM   #434
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Yep. I'm doing it. May build an HEI too. Will post back as things develop.
Here's the shop I have in mind, owner seems like a nice and extremely knowledgeable guy: https://www.advanceddistributors.com/
Old 03-19-2024, 04:28 PM   #435
PowerdbyChevy79
PowerdbyChevy79's Avatar
Subscribed!!!
Im about to start a K5 build soon.. lots of great info on here.
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is online now   Reply With Quote
Old 03-20-2024, 09:15 AM   #436
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Welcome aboard and thanks for the good words. The build continues. Recently, I replaced the HEI with the original points distributor, which I sent for a rebuild and curve. The HEI left me temporarily stranded a few times and rather than disassemble it and replace the pickup coil I decided to can it.
Engine runs and idles better than ever but I’ve yet to do a long drive. Since I used a harness designed for use with an HEI that has no resistance built in the external coil I added has internal resistance. This coil has a slightly larger diameter than an OE example but fit in the OE bracket. The new plug wires are from Lectric Limited are US made and are precut for a 72 4wd application.
Old 05-19-2024, 10:41 AM   #437
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I’ve been able to get some seat time with the rebuilt distributor. This thing has never run better. Easier starts, just purrs at idle, and there’s great throttle response. Super pleased I did the swap. Fresh oil and a new coat of wax - ready for the summer.
Old 05-19-2024, 10:54 AM   #438
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Nice, looking good too.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 05-19-2024, 11:03 AM   #439
IronCanine
I'm trying....
IronCanine's Avatar
Damn that girl is PHOTOGENIC.
Glad the distributor rebuild panned out so well. Following your lead per usual.
Old 05-19-2024, 05:26 PM   #440
1970cstblazer
1970cstblazer's Avatar
My 1972 Cheyenne responded the same. The MSD didn't cut the mustard. The rebuilt correct points distributor for the win!
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 05-22-2024, 10:22 AM   #441
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for the good words guys. It's as if the Blazer was pouting about the lack of its original distributor. Sort of like that Brady Bunch episode where they took the idol from Hawaii and bad luck followed The K20 gets along just fine with the HEI or so it seems.
Old 05-22-2024, 10:51 AM   #442
1970cstblazer
Lightbulb Re: 1972 Medium Blue Highlander Blazer Resto
To make it clear, I am a fan of HEI systems. My mid-70's Pontiacs have had zero issues with them, especially after a recurve and maintenance to include replacing the pick up coil.
In these '67-'72 trucks, especially K series, I do not like them. The engine sits close to the firewall, and the larger diameter of the HEI distributor is not favorable. Also, the stock centrifugal/vacuum advance timing calibrations are for smog era low CR and wussy cams. Of course, these are easily addressed.
As with the points system, quality old stock parts are crucial. Most of the new parts available today are of much lower quality than OEM Delco Remy.
