Old 02-07-2024, 10:42 PM   #1
jlampka
PS Pitman Shaft Seal Orientation 1972 GMC BB
I just watched a video of a pitman shaft leak repair and they showed that both seals to be oriented with the flat side of both seals down towards the ground. I am getting ready to install them tomorrow on my 1972 GMC with PS, with 402 engine. Anyone do this before? Thanks in advance!
Jeff
jlampka is offline   Reply With Quote
Old 02-08-2024, 12:14 AM   #2
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: PS Pitman Shaft Seal Orientation 1972 GMC BB
fine looking rig, do you have a gallery? What kind o' paint did you use for that?
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is online now   Reply With Quote
Old 02-08-2024, 01:53 PM   #3
kwmech
Yup, done it quite a bit. Fun times getting the old ones out. Orientation is like you said. Getting the old ones out---get a small drill and CAREFULLY drill a couple of holes through the seal (180 apart) enough to screw a long sheet metal screw into them use a pair of wire cutters to get leverage and pry it out. Does that make sense? There may be a flat washer in between the seals so a small magnet and screw driver will also be needed.
kwmech is online now   Reply With Quote
Old 02-08-2024, 02:06 PM   #4
PbFut
The seal can be pretty easy to pull but if you have luck like me nearly impossible. I spent about 4 hours attempting removal. Ended up completely disassembling and it was still a bugger. There is a very good write up on this forum I used as reference. I'll see if I can find and post the link. Good luck. Hope that seal pops easier than mine did.
Here it is. Good info https://67-72chevytrucks.com/vboard/...d.php?t=619634
PbFut is offline   Reply With Quote
