Old 02-08-2024, 06:03 PM   #1
PbFut
Vent Window Gasket Photo Request
Most of the gaskets I see, at shows and such, are often tucked into the door. I don't think that is correct. Can someone take photos of the vent window installed relative to the door showing the gasket lip orientation to the door. Both in and out. Also, a really close shot of the upper most corner area of the gasket and frame attachment point of the two frame pieces. I seem to have a tiny gap that I am sure is not supposed to be there. I do not have the window installed so maybe that area squishes some when pushed into the door channel and tighten things up. I did not notice when I riveted together, but now I am questioning myself if I allowed the tolerance of those parts to open up some when I hammered things home. First time doing these vents and so my confidence is low.
Thanks for assistance.
PbFut is offline   Reply With Quote
Old 02-08-2024, 06:43 PM   #2
twoskies
twoskies's Avatar
Re: Vent Window Gasket Photo Request
i just rebuilt mine and thought they were supposed to be on the outside
but looked through some other posts and they are tucked inside
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 02-08-2024, 09:20 PM   #3
PbFut
Hank you. Humm. The waterproofing gene in me(father was a union painter) says that's going to allow penetration. But I guess the side window scraper is not perfect either.
So inside the channel on both in and outside? It just rubs me wrong. The gasket on the truck was half in and half out. Removing indicated it was original as the construction and trim was clearly factory.
Old 02-09-2024, 09:05 AM   #4
A1971Blazer
A1971Blazer's Avatar
they tuck inside which seems counterproductive to sealing out water...
that's why there are drain holes in the door bottoms (which in turn, get plugged and rust out the door bottoms)...it's a vicious cycle...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 02-09-2024, 11:57 AM   #5
PbFut
Got it. Inside it is. Thanks all
Old 02-09-2024, 01:05 PM   #6
jaros44sr
jaros44sr's Avatar
If it is longer on the outside, doesn't it mean it is designed to be over the door
17074980167217607450904449355187 by 17074983764643951626142437202710 by [url=https://www.flickr.com/photos/97391199@N06
Hence the need to be rebuilt, paid 10 bucks for it on our classified
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-09-2024, 06:50 PM   #7
72c20customcamper
72c20customcamper's Avatar
It should be tucked in and fit snugly . Doors are not water tight to begin with hence they have drain holes at the bottom . I worked on these trucks when they were fairly new and skinned many doors . Always tucked the rubber in with a paint stick and rubber lube the flap that tucks in stops wind from going under the rubber and making noise
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 02-09-2024, 06:57 PM   #8
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Its called planned obsolescence...
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
