Carpe manana
![]() ![]() Join Date: Dec 2010
WTB: Tach/dwell meter
Looking for a working, US made Tach/dwell meter like the Sears example I gave my brother a generation ago. I might go back to a points distributor. Thanks for the help.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
![]() Join Date: Jul 2001
Re: WTB: Tach/dwell meter
Pete, let me check in the garage/shop dark corners and get back with you. Think I still have my RAC (Rite Autotronics) unit along with my Sears chrome inductive timing light. Haven't used either in some time. Will look and see if your interested? It worked fine last time I used it.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Carpe manana
Thanks, I appreciate that. I kept a hold of my chrome Sears timing light - that’s a fun tool to use.
#4 | |
![]() Join Date: Sep 2010
Posted via Mobile Device |
lots of choices on flea bay if you don't find it here - good luck!
btw, I still have points in three of my trucks ![]() $25 Vintage Sears Dwell Tachometer Model 161-2177 ![]() $25 Vintage Sears Dwell Meter 244.2185 ![]() $12.99 Rite Autotronics Corp. RAC Dwell Tach Points Tester Model 1557 in box
I started out with nothing - and I still have most of it |
#6 | ||
Carpe manana
Not that nostalgic, lol.
![]() ![]() Join Date: Sep 2008
I had an Actron for years and it grew legs and walked out of my shop. I found a like new replacement on Ebay.
The Arkansas K10 has the proper points and condenser. Runs like a top.
#8 | |
Pete, found the RAC hand held dwell/tach as mentioned. Will post up a few pics later this afternoon.
Carpe manana
Sounds good PM sent.
Thanks! Maybe this could be a good backup.
Pete, got a pic of the dwell/tach and was wrong on the mfg. It is a Hawk dwell/tach, has worked well for me but no longer use it. I converted my '71 4x4 and '71 Chevelle both to the Pertronix Igniter II ignition system. Since the engine on a 4x4 sits back further that worked out well not having room for a big cap GM HEI ignition and it still looks stock.
Dwell/tach wires and clips are in good shape, hair line crack across the top of the lens but no breaks or missing lens material. Still has a nice clean face and easily readable. Do not have a points vehicle to test it on but if it arrives to you and does not work money will be refunded. $20 shipped to you if interested.
Carpe manana
Thanks. Sending PM
![]() ![]() Join Date: Jul 2003
I just rebuilt the original points distributor for my 1970. Here is a list of genuine USA made NOS Delco parts I used to bring it back: List is for 1972 350 Blazer: Cap: D308R/ 12338667 OR 1971244 Rotor: D409/1932015 The light duty rotor D426R 1852722 is an option, but I never liked them. Points: D106P/1931988 Condenser: D204/1932004 Uniset points/condenser: D1007 1876600 Vacuum advance can: 1973437 Coil: D512/1115238 I used repro plug wires date coded for my application from this seller: https://www.ebay.com/itm/253117261028?hash=item3aeef6e4e4:g:P-gAAOSw7Cdh2Nuk&amdata=enc%3AAQAIAAAA0O3W8EOJGfGq%2FcSXcKlZ5ENh%2BR2WlOm%2F%2BN5YkgUHIylyj6FGxhCsDXz4 RrvElItUEb2g3DPu6bytG2rqnGGkHNCN%2FKUkPghzb%2FeYv6cyl2SmP2QiCyr2R9NcersrgCCkowYm784FJWqNB4a58eocXS74 QuCFJqudHImy%2Bd9b3gWptrQLzix2mYxotVSBHQRUIsghhqgH%2BDD%2FEXLb6YH4S662gPt3sLXLY9FfrZZ%2BzYJr0mKLCzRs 8s3IduI40fz6ebbobMy%2FNQ7Fk25JM%2BQtMkk%3D%7Ctkp%3ABk9SR9qt19ezYw
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels Last edited by 1970cstblazer; 02-12-2024 at 10:49 AM. |
Carpe manana
Thanks! That's a huge help. I'd like to post your p/n's to a thread I started HERE about reconfiguring for points with an engine harness designed for use w an HEI.
I've got Delco points and rotors (D426r, didn't know to look for D409) on the way and Napa had a US made black with copper/brass cap. I've got very similar possible the same wires from Lectric Limited HERE
#15 |
Couple of years ago when I was still running points I went looking for a handheld dwell meter to tune my 71 C/20. Asking around town , no one even knew what I was talking about. Just about everyone around me that was knowledgeable on older vehicles has either died or moved away. Kid at Napa just had a dumb look when I asked him about one.
71 C-20 07 Magnum RT AWD |
#16 |
if you're "rebuilding" a distributor, don't forget breaker plate bushing/spacer, shaft bushings/thrust washers, etc.
wobbling shaft/breaker plate will give you much grief with all brand new points, cap, rotor, etc. replaced my first distributor at 16yo for this reason, jumping through my butt chasing my tail to get steady timing also learned how to static time a v8 olds over the phone with the store I bought it from
#17 |
Mine was not loose, therefore not mentioned. Good info to add..
Don't forget the points cam lubricator, or just a small amount of distributor cam lube.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#18 |
Pete, received $$ this morning and just got back from shipping the dwell/tach your direction. As mentioned, if the dwell/tach no longer works let me know and I will refund the $$. Do not have a points vehicle any longer to test it with since I changed over to the Pertronix Igniter ignition. PM sent with tracking info, thanks again for the purchase.
#19 |
Carpe manana
Thanks Gary!
| Bookmarks |
