Old 02-04-2024, 10:10 AM   #1
1981_c10
1981_c10's Avatar
LS Swap Exhaust
What are you guys doing for exhaust for your LS swap? I am running 5.3 ls with speed engineering long tube headers.
I have looked at speed engineering kit and hooker blackheart but just havent heard them before so trying to get some feedback before choosing what i want.
Goal: have a nice rumble for shows but i plan to drive and dont want it crazy loud in the cab when going down highway.
Builds:
1962 C10 Recreating Dad's High School Truck
1981 C10
1981_c10 is offline   Reply With Quote
Old 02-04-2024, 05:16 PM   #2
cdub2010
Re: LS Swap Exhaust
I used the speed engineering swap headers with a 2.5 inch stainless bend kit. I cut and welded up my exhaust with Summit racing 409 stainless 2.5 mufflers 14 inch long i believe and 3" flowmaster prebent tailpipes on my '77 k20 5.3. I didnt put in a x or h pipe, just true duals, because I was in a hurry to get it done. It sounds fine, gets noticed with the stock cam but it think its a bit loud at wide open. I dont think ls engines sound have a good sound anyways, so its all personal preference.
It cruises nice on the highway at 80, no drone or buzzing. Ive done 600 mile trips several times and its quite enough for what it is.
cdub2010 is offline   Reply With Quote
Old 02-05-2024, 12:09 PM   #3
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: LS Swap Exhaust
I have a '13 (gen IV) in a '86 C10 and I used Pacesetters "shorty (block hugger) headers and the stock cats (w/ all 4 O2 sensors) and had a muffler shop do a "custom" exhaust with Xpipe and exit each side in front of rear tires.
rodstored-72 is offline   Reply With Quote
Old 02-05-2024, 04:35 PM   #4
mongocanfly
mongocanfly's Avatar
Re: LS Swap Exhaust
I'm running headers and duals on mine..turned down in front of rear axle..
Not crazy loud, but has good tone..
The are magnaflow knockoffs, called magflow, they've since changed the name to maxflow..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-06-2024, 05:33 PM   #5
Nick_R_23
Nick_R_23's Avatar
Re: LS Swap Exhaust
Gen 5 Camaro manifolds.
Old 02-14-2024, 04:06 PM   #6
TotallyHucked
TotallyHucked's Avatar
Re: LS Swap Exhaust
I'll see if I can get some videos posted too. I've got an '85 with the 5.3 with Speed Engineering 1 3/4" headers. I bought an amazon X-pipe piece and a pair of Borla ProXS mufflers. Had an exhaust shop bend me up a custom 2.5" exhaust all the way out the back. Sounded really good, had a mellow idle but a very unique sound at WOT
Name:  Exhaust shop 6.jpg
The ProXS's started droning worse and worse as time went on until I couldn't stand it anymore. So when I swapped in the T56, I swapped to some universal Corsa's mounted behind the axle. They're entirely too loud on the outside but they're very quiet inside. Gonna add some resonators to tone it down a touch and calm down the part throttle "clap" they have but overall this is much better than the first setup
1985 GMC Sierra Classic
Chopped down wrongbed
Cammed LH6 5.3/T56/3.90
Walker Tuned
5/8 drop
US Mags
TotallyHucked is offline   Reply With Quote
Old 02-15-2024, 12:26 PM   #7
TotallyHucked
Re: LS Swap Exhaust
Here's the old setup with the Borla's when they were knew. Didn't even have 10mi on the swap at this point lol
https://www.youtube.com/watch?v=I8TjMq0IDR4
Here's the current setup with the Corsa's, I don't have any outside video at this point
https://www.youtube.com/shorts/SLn3uW5zBQY
Walker Tuned
5/8 drop
US Mags
Old 02-15-2024, 12:36 PM   #8
dagnabbitt
dagnabbitt's Avatar
Re: LS Swap Exhaust
That sounds pretty great.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
dagnabbitt is online now   Reply With Quote
Old 10-19-2024, 07:53 AM   #9
1981_c10
1981_c10's Avatar
Re: LS Swap Exhaust
Help please!
I bought the speed engineering 3 inch kit with x pipe that is designed to run with their long tube swap headers, their trans mount and 4el60....tried putting on yesterday and fitment is less than ideal.
Any one put this kit on? My x pipe dives down pretty hard under the drive shaft causing the rear portion of the system to sit very low which can be seen from the side....
Tried calling customer support to ask for instructions, pictures and guidance, to everyone's surprise...yeah they didnt help at all.
Builds:
1981 C10
Old 10-19-2024, 11:42 AM   #10
kglowacky
Re: LS Swap Exhaust
I just ran factory set up I bought from Summit and had a muffler shop adapt them to the exhaust manifold. Very quiet but as years and miles go by they are getting louder .
kglowacky is offline   Reply With Quote
Old 10-20-2024, 07:33 AM   #11
WorldsCrappiestTruck
Re: LS Swap Exhaust
Originally Posted by 1981_c10 View Post
Help please!
Do you need to angle-up the whole driveline a couple degrees to allow the X pipe to sit higher? A different transmission mount?
The angle of the headers will drive the “height” of the x-pipe. The angle of the engine & trans will drive the angle of the headers.
WorldsCrappiestTruck is offline   Reply With Quote
Old 10-26-2024, 08:22 AM   #12
1981_c10
1981_c10's Avatar
Re: LS Swap Exhaust
Vendor recommends using their trans mount they sent which is flat. From headers pipes jump over trans crossmember then dive under driveshaft and connect the x pipe right at yoke. x pipe is just angled down pretty hard. thinking i will have to take to a shop to fit properly...so much for bolt in.
Builds:
1981 C10
Old 10-29-2024, 11:50 AM   #13
Hart_Rod
Hart_Rod's Avatar
Re: LS Swap Exhaust
I used the Blackheart kit on my LT engine swap with the hooker manifolds and it bolted right in.
Hart_Rod is offline   Reply With Quote
Old 10-31-2024, 12:55 PM   #14
Loco83
Loco83's Avatar
Re: LS Swap Exhaust
Nice.
Loco83 is offline   Reply With Quote
