Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 02-18-2024, 04:02 PM   #5251
72c20customcamper
72c20customcamper's Avatar
Re: What did you do today not on your truck...
Skimmed the ice from the sap barrel . The ice contains very little sugar as evident from the refractometer. The thawed ice has almost zero sugar we as the liquid in the bucket has almost 5% sugar . Difficult getting a picture down the site glass
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 02-18-2024, 07:56 PM   #5252
dieseldawg142
dieseldawg142's Avatar
buffed my wife's headlights today.....
no, not those ones, these ones...
dieseldawg142 is offline   Reply With Quote
Old 02-19-2024, 10:44 AM   #5253
Yes, I understand. But did you doing this for her give here hi-beams?
Old 02-19-2024, 06:56 PM   #5254
72c20customcamper
Doing a muffler modification on the Husqvarna 395xp . Not doing to up the HP but that will happen . Main reason is because the way the exhaust port was pointed it would direct the fumes at me when I am milling wood . This way the exhaust will go up and away from me instead of down towards me . Made a block off plate for the old port . Just replaced the spark arrester
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-20-2024, 02:43 AM   #5255
LT7A
Twice pipes!
Old 02-20-2024, 07:53 AM   #5256
Ready for some lumberjack competition now! I had an early John Deere 110 lawn tractor and the exhaust the dealer sold me only fit with the canister muffler in the horizontal position when it was meant to mount vertical. That put the outlet pointing straight up, causing the exhaust to float right back at me. I went to the exhaust shop and had then make me a stack with a turnout just like the big boys. I have everybody wanting to buy that 110 because of that stack
Old 02-20-2024, 08:17 AM   #5257
robs71
robs71's Avatar
Finished putting the interior back together on the old demon trying to retain everything as it was back in the day plus got the old hurst slapstick to work..you tube video,google Holley MoParty 2021 with Mike Musto and Dylan McCool about 00:49 ..,little walk around of the car,she ain't pretty.....Rob
robs71 is offline   Reply With Quote
Old 02-20-2024, 09:29 AM   #5258
72c20customcamper
No competitions. This is a work saw it’ll be loud but not much more performance than a stock saw. I have a Dolmar 7190 that’s has been semi competition built . Ported polished the compression has been bumped up unlimited rpm coil advanced timing etc. It is a strong runner but not something you use all day . Used in big wood only this one is for milling so it runs for long periods .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-20-2024, 06:11 PM   #5259
72c20customcamper
I made a deflector but decided against it as it would have one of the muffler bolts inside it so the final decision is staggered dual pipes . I cut the muffler already just need to clean it up
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-20-2024, 06:14 PM   #5260
72c20customcamper
Little playing around thought the ricer crowd would like it
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-20-2024, 07:38 PM   #5261
Steeveedee
Who Changed This?
Steeveedee's Avatar
Did that can used to have beans in it?
~Steven
Simi Valley, CA
Old 02-20-2024, 07:41 PM   #5262
72c20customcamper
Yes it did . Fart can
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-20-2024, 09:21 PM   #5263
tutone
tutone's Avatar
I have enough trouble keeping my 2 saws going as it is. My problem seems to be the only trees that fall over on our place, are hickorys. Great firewood, but they sure are hard on chains.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5
tutone is offline   Reply With Quote
Old 02-20-2024, 10:31 PM   #5264
Steeveedee
Who Changed This?
Steeveedee's Avatar
I didn't think we got away with saying that word here.
~Steven
Simi Valley, CA
Old 02-21-2024, 01:54 PM   #5265
72c20customcamper
Cutting hardwoods I tend to go with a 25 degree angle on the cutters . Less aggressive takes longer but the chain stays sharper much longer . Removed the limiters on the carb adjustment screws so I can fatten up the mix . The little cam keeps the adjusters to the lean side to meet EPA emissions standards. And that’s not good even on a stock saw
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-21-2024, 02:46 PM   #5266
Rich84
Rich84's Avatar
Tree company stopped by our property today. They want to cut a massive old oak tree that is leaning over the power lines. She is about 6' in diameter but showing her age. I figure it's probably a 7-10 thousand $ job. The power company has been aggressive lately with their trimming and cutting.
Rich84 is offline   Reply With Quote
Old 02-21-2024, 02:50 PM   #5267
72c20customcamper
Been going on here too . I guess they finally figured it out that it’s easier and cheaper to do preventative maintenance than emergency repairs . I’ve been getting wood all fall and winter on the roadside
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-22-2024, 02:33 AM   #5268
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
Sanded my Baja hood today. I still have some fiberglass work to do to fill in and smooth it all out. I'm using my old junk parts. Why not? The price is right and I don't mind working with fiberglass. It's not that tough to fix cosmetic stuff. I put the latches in Evapo-Rust to clean them up as they were rusty. They haven't been in it that long but it's looking promising. I threw in some rusty pliers and when I checked they were as shiny as a bald guys forehead. Evapo-Rust seems to be working. Fingers crossed.
But that bucket was a PITA to open. My uber smart wife figured it out before I blew a blood vessel fighting with it. It was easy. (for her) She popped the tabs on the side while I was screaming and looking for a sledge hammer to bust it open. Fortunately cooler heads prevailed.
And I took a pic of the wrong side of the hood. I should have let her do it
The blue thing in the pic is my German Shepherd's Frisbee. It's only a few days old and just look at it. I wouldn't want that dog to bite me. He's strong, built like a tank. It'll be destroyed by Friday.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 02-22-2024, 09:14 AM   #5269
LT7A
This is cool. Have you started a thread in alternate tinkerings? I'd like to see and hear more.
Old 02-22-2024, 09:19 AM   #5270
LT7A
Cool! More pitchers please!
I watched a video by Edd China formerly of Wheeler dealers on youtube. I was pretty impressed with evap o rust. I thought it was just a commercially available mixture of vinegar, or one of the other acids. Turns out, it seems that it's much less caustic and destructive to the parts.
Old 02-22-2024, 01:17 PM   #5271
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Our old wolfdog was like that. Anything said to be "indestructible" was just another challenge to him. Kong toys? Pffffttt. Once bought him an indestructible dog bed. A few days later, what was left of it went to the dump.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-22-2024, 01:51 PM   #5272
robs71
robs71's Avatar
No have not started any threads,,have to think about that.
Old 02-22-2024, 05:10 PM   #5273
FleetsidePaul
R.I.P. E.S.L.L.
These were totally rusted and frozen up. They had been laying in the mud in the bed of my dually for years when I bought it. I thought that they were goners. Just one night in the "bath' and here they are. And the stuff is like water. It doesn't stink or anything. I'm impressed.
Got me some free tools!
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Old 02-22-2024, 07:13 PM   #5274
72c20customcamper
Picked up some black walnut this morning and then a load of oak. The oak is just some of the limbs I have to go back for the trunk . Need the big saw with the 36 inch bar
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-24-2024, 01:15 AM   #5275
FleetsidePaul
R.I.P. E.S.L.L.
I pulled off the bottom latches on the buggy (the big one). The top ones came out pretty good so hopefully the bottom will too. The top looked worse than the bottom before. I also put new bolts on them too to give them some shiny. So into the dip go the others.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
