#26 |
Re: 1970 Jiffy Mount Tire C10 build
-------------- 1970 C/10 LWB build thread: https://67-72chevytrucks.com/vboard/...d.php?t=847860 IG- Tip70 |
#27 |
getting close to finishing up this side. I have a few holes to fill, that I was having trouble getting a good weld without blow out. I bought some more wire and went with a smaller size .025 down from the .030 I had on hand. Which on some test welds with the other side, is laying down smoother.
I put down some tape and paint to clean up the lines to make them straight. deciding still if id like to keep the welds or hide them. we will see ![]()
#28 |
Active Member
![]() Join Date: Oct 2012
Good progress!
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#29 |
![]() Join Date: Aug 2004
Nice work, I like how you did your cuts.
You will have a much easier time with the thinner wire.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#30 | |
![]() the cut lines I went off from was the Brothers truck video with David Welch. He walked through it in great detail
#31 |
#32 |
update pics, getting closer to finishing up the bed. Then I will be able to get the truck back in the shop and start on the frame!
#33 |
![]() Join Date: Jun 2002
Great work, it will be like having a whole new truck when you are done.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#34 | |
#35 |
I finished up the box. The welds aren't perfect but I'm liking it. Now I'm waiting on some clear weather to swap out for the truck that's on the side of the house. Garage is too small for both. I just received my conversion kit from long shot fab, so I'm itching to get cutting
![]() I've always kicked myself that I did not save my old tailgate for the embossed letters to graft into the one I have now. But for now some weathered painted letters will do ![]()
#36 |
Got the truck in the garage, lets get to cuttin!
#37 |
Active Member
Good luck! The short bed looks great, nice job.
#38 |
#39 |
Haven't been updating the progress lately, sorry for that. here are some pics of the Long Shot fab kit installed and frame cut. Also the rear cab mount moved back. Thought I had pics of the frame bolted back together, but I guess I never did
#40 |
Here are some shots of the truck. Loving the look of the shortness
![]() ![]() All I have to do now is fix the gas line, brake line, and rerun the air lines and wiring with the bed back on, so I can move it over to my friend that will weld it up right! getting close!
Tags |
1970 |
