Old 02-23-2024, 01:30 PM   #151
Jason Banks
Jason Banks's Avatar
Re: My 1967 Chevy K20 Build Thread
Great! RB-117 is what I had come up with to cross reference to the 468481 Part number I had found for the bushing. Hopefully they can get them installed!
He kept trying to explain to me the 117 was used on newer trucks, and I was saying 'please just check it out'.
Jason Banks is offline   Reply With Quote
Old 02-23-2024, 01:35 PM   #152
Chaparralman1974
Chaparralman1974's Avatar
Yeah, it is always a good idea to have them double check! I was not happy with Dunbar in the end. They didn't do all the work that I had been told they would do. I ended up taking the leaves back apart when I got home and cleaned them up myself. I will likely not use them again, but in their defense, the bushings did turn out ok. Everything on my chassis is sitting nice and level now.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 04-08-2024, 11:17 AM   #153
Chaparralman1974
2/10/2024 - 4/8/2024
Steering Gear and Carburetor Rebuild
I needed a break from some of the body work, so I decided to begin the rebuild process of both the steering gear box and the carburetor. I am still not 100% sure what I am going to end up with regarding the steering system. I originally wanted to add power steering to the truck, but in order to do so, I would have to graft in a dimple in my totally virgin frame to accomodate the proper steering gear box, as well as source a pump and all of the other components necessary. Another challenge would be the steering arm. My closed knuckle axle has a straight steering arm that would need to be modified in order to work. Given the fact that I want the truck to be as factory looking as possible, I really don’t want to cut the steering arm or replace the front axle. I also looked into the possibility of adding an EPAS system. I may do that in the future, but for now, I decided to just rebuild the manual steering gear. It was not at all that difficult to do. I completely tore down the box, cleaned it, sand blasted and painted it satin black. As this is a standard Saginaw design, and parts are readily available, I was able to get a rebuild kit from Midwest steering and rebuilt the box in short order. I replaced all the bearings, seals, and bushings, and at the recommendation of Midwest steering, filled the box with lithium grease. I did have to do a slight modification to the pitman arm and steering arm with the tapered holes for the tie rods to go into. As they no longer manufacture the one piece tie rod, I had to use the three piece design present on later model 4x4’s. These tie rods are thicker, so I had to ream out the holes using a 7* reamer so that the tie rods would slide in.
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 04-08-2024, 11:19 AM   #154
Chaparralman1974
I next moved onto the carburetor. It was trashed. Mice had made a home out of it and the throttle shafts were seized in place. Nothing on it moved freely and the throttle body plate was corroded beyond help. At some point, someone tried to force the primary throttle shaft to move and twisted it. I tore the entire thing down, soaked everything in carburetor cleaner and then removed the brass tubes, needles, seat, jets, etc. and cleaned out every passage with welding tips. I was able to find another throttle body on eBay and then got a complete rebuild kit from Quadrajetpower.com. They have some AMAZING videos on the quadrajet rebuild process and I found that by and large this was a fairly easy rebuild. Once I got all of the parts, I was able to get the carburetor completely rebuilt. I also have been playing around with Caswell black oxide treatment to refinish all of the hardware on the truck. The carburetor has been no different. I blasted all of the screws, nuts, bolts, etc. and gave them a good treatment with the black oxide solution. This stuff really gives a nice looking rust free treatment that should allow them to live for another 60 years!
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 04-08-2024, 09:52 PM   #155
72 tigger
72 tigger's Avatar
Beautiful work as always!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 04-08-2024, 10:20 PM   #156
Chaparralman1974
Thanks Kirk! She’s getting there! I am really looking forward to getting a bed back on it so it once again looks like a truck!
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 04-09-2024, 09:23 AM   #157
raggedjim
raggedjim's Avatar
Great work on this. Sticking with it through the cab work is a tough thing to do!
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 04-10-2024, 02:04 PM   #158
loudchevy
Active Member
loudchevy's Avatar
Carb cleaned up nicely!
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 04-10-2024, 03:44 PM   #159
Chaparralman1974
Thanks Scott! I just hope it works! LOL!!
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 04-14-2024, 10:15 PM   #160
LT7A
Was cool to read through your thread. I appreciate the efforts towards originality and the attention to detail.
Old 04-15-2024, 09:16 AM   #161
Chaparralman1974
Thanks much! It has definitely been a labor of love for me.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 04-16-2024, 01:25 PM   #162
Short 3/4
Hey Clay,
Just catching up on your build. Always a pleasure to see how your progress is going. I recently recommended this thread to a guy restoring a similar truck, as your research and the detailed documentation of your fine work is second to none.
I’m glad to see you decided to go with the stock manual steering. I’m always amazed how many think they “need” power steering, without actually driving the truck for awhile. With stockish sized radial truck tires (I’ve always used 235/85R-16’s) the steering gears are low enough and the steering wheel large enough that even around town and off road is usually not a problem. FWIW even my 66 year old wife occasionally drives mine with no complaints.
Keep up the good work. I’m really enjoying following along.
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 04-16-2024, 01:51 PM   #163
Chaparralman1974
Originally Posted by Short 3/4 View Post
Hey Clay,
Tom
Hi Tom, and thank you for the kind words! Yeah, I think that the manual steering will suffice for now. I am still tossing around the idea of adding an electronic powersteering setup in the future, but for now I am focused on just getting the old girl back on the road. :-)
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 04-18-2024, 09:46 AM   #164
Jason Banks
Clay, could you get me pictures and possibly measurements of the parking brake parts I have circled in these pictures? They are missing on my truck.
I ordered all new cables from Inline Tube and the front an rear cables fit fine. - https://www.inlinetube.com/products/sbst6713
The intermediate cable they sent is shorter than the NOS cable(which appears to be the correct part number), but I haven't tried either one yet since I don't have any of the pieces pictured.
Old 04-18-2024, 02:28 PM   #165
Chaparralman1974
Hi Jason, the cab is on the truck now, so I crawled under and tried to get a measurement of the parts you circled. The long rod on the passenger side appears to be about 15 3/4" and the shorter one on the driver side is about 3". It was kinda hard to get my head up in there and hold the camera steady.
Here is a link with a bunch of pictures that I took during the tear down along with a few videos that documented how all the cables were situated in the frame.
https://share.icloud.com/photos/021d...hc2mWcfmRC6chQ
Let me know if you need any additional pictures or anything.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 04-18-2024, 03:51 PM   #166
Jason Banks
Holy crap, those pictures are amazing. Thank you so much!
I was able to rig mine to work. I may make a version of that longer rod.
I had this kit from Inline Tube for another truck - https://www.inlinetube.com/products/inl14355
The shorter brackets are probably the same as what you have.
But the long rod is just straight and not a hook. On a 1/2ton 2wd there is a dimple on the frame it rests on. I just put a bigger washer on it so it wouldn't pull through the hole on my frame. If I can't make a hooked rod, I may make a more elegant plate with an angled surface for the washer on the rod to rest against.
The intermediate cable that was included with the cables from Inline Tube was too short, but the NOS cable 3894291 worked fine.
Old 04-18-2024, 03:59 PM   #167
Jason Banks
I'm going to watch that video about 50 times.
I noticed your brake lines are routed identical to mine. I ordered the full line set from Inline Tube and they were not even close, so I sent in my old ones and they duplicated them for me.
I don't have a hose on the vent for my rear diff. My vent just like a little breather cap.
Looks like your truck has the HD rear spring option like mine has too.
Hard to believe they only made 2773 Fleetside K20's in 1967...
Old 04-18-2024, 04:52 PM   #168
Chaparralman1974
Hey Jason!
Anytime on the pictures! We are all in this together! LOL
I am going to try to reuse my brake lines. They weren't that bad, but the were wasted as they went into the "T" fittings on the front and back. I am hoping that I can just splice in some new brake lines with some unions. Truth be told, I have been procrastinating on it. I need to get out there and get it done.
I made sure to take thousands of before pictures to use as a reference, so if they aren't in my build thread, let me know and I can post some more.
And I agree about the low count of these trucks. Sadly, many of the K20's were worked to total junk. Those that are left have been cut down to shorty's. I am trying to keep this one as original as possible. I may change my mind later on down the road, but for now getting the old girl back on the road is the top priority.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 06-11-2024, 08:56 AM   #169
Chaparralman1974
8/1/2023 - 6/11/2024
Body work, body work, and more body work
I HATE BODY WORK!!!!!
By far, the most grueling part of this entire project has been the body working phase. Over the past 12 months or so, I have been doing primarily body work with detours into other areas of the project that are a lot more fun. I will say that I have learned a lot about doing body work and can fully appreciate why professionals charge what they do for quality work. I have also had to change directions on a few things along the way. I had really wanted to keep all of the original sheet metal on the truck, but economics and common sense win the race there. For example, I tried to fix the hood which had severe oil canning in it with heat shrinking, but that is an art in and of itself. I ended up just going with an aftermarket hood and it fits like a glove! The part that I used was AMD 300-4067 and it seemed to line up with the original fenders perfectly.
The next thing that I changed direction on was the bed. I really wanted to try to salvage it as well, but I was able to find a near perfect bed off of a ‘68 that has a wood floor in it, so I am going that route instead. All of the other panels, doors, fenders, etc. were in really good condition and were able to be reworked. The only exception there was with the cowl that was so far twisted and welded on, that I just found a replacement on FB marketplace.
After doing all of the body work, I resealed it with Eastwood Epoxy Primer and then followed up with 3 coats of Eastwood High Build Primer / Surfacer. After I finalize primering the hood and get the bed stripped, it will be onto final block sanding. I think that I have also decided to attempt to paint this myself. Originally, I wanted to farm that out, but I figure, what the heck? What is the worst that can happen?
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 06-11-2024, 08:57 AM   #170
Chaparralman1974
More....
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 06-11-2024, 08:59 AM   #171
Chaparralman1974
More...
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 06-11-2024, 09:03 AM   #172
Chaparralman1974
Even more....have I said how much I HATE body work??? LOL
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 06-11-2024, 09:05 AM   #173
Chaparralman1974
At least it is starting to look like a truck again!
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 06-11-2024, 09:48 AM   #174
loudchevy
Active Member
loudchevy's Avatar
Great job, Clay. Glad you could find a new hood! Def nice to see it coming back together.
Scott
2003 Tahoe Stock
Old 06-11-2024, 10:02 AM   #175
Chaparralman1974
Thanks Scott!
She is getting there! I found a nice bed in Denver and I am going to do a road trip on Thursday to go and get it! Crazy, I know....but it will get me one step closer to getting this thing done. :-)
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
